More proof I am an idiot
   / More proof I am an idiot #31
When I see a rock, I aim my backhoe at it, dig it out and usually put it in my creek in washout areas. Before I got my backhoe, it was pick and shovel which was no fun as some of them could be quite large with only the tip exposed.
You need some rocks around the edge of that pond . Kevin .
M5040 you need to experience tree wrap then you are a true pt owner. I did one that somehow got me around a 14 inch alder that was so bad I had the tree jammed between the engine cover and the rops. Had to start cutting the tree down by standing on the roof.
   / More proof I am an idiot #33
Feel free to add to the list....
PT Pucker - check
Tree wrap - check
Slide downhill sideways against a fence - bucket list
Throw dirt on lap with FEL - check
Make air hose pass-through port on side of garage with tooth bucket - check
Operate QA before disconnecting hydraulic hoses - check
Try to operate QA without connecting hydraulic hoses - check
   / More proof I am an idiot #35
That low COG sure makes a difference!
That is why many of us own PTs...:laughing: We are big :fan: :fan: of low COG.
Just trying to stay safe while getting the job done.
   / More proof I am an idiot #36
It is amazing how much snow plowing you can do sometimes before you realize you did not engage the hydraulic quick attach tabs. I actually tore a plow hose one of the times I did that. Makes up for my not having done Moss' airline pass through hole nor the fence. I can check the other boxes. I am sure there are plenty of other boxes I can check but they are just not coming to mind at the moment.
Ken
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
CAT 336E (A58214)
CAT 336E (A58214)
