More Post Hole Dig Advice
/ More Post Hole Dig Advice #1
Alex_Mendoza
San Diego, CA
JD 4115
Hello Gentlemen:
Once again I thank you in advance for your input, I got a Deere 4115 with a Land Pride 15 series PHD with a 12 inch auger (puting some plastic 3 rail fence 5x5 posts) the auger works great as long as the groung is fairly soft, I came upon some hard dirt and was able to go about 8 inches or so before I had trouble, I stopped and filled the hole with water and tried again the following morning with fairly good results.
Would using a 6 inch auger to do an initial hole (pilot hole) and then using the 12 inch auger make the job any faster? any other ideas?
Thanks again for your input.
Alex
/ More Post Hole Dig Advice #2
It is my understanding that the bit is what does the biting and the flighting just removes the dirt. Drilling a pilot hole with a smaller auger wouldn't gain you anything that I'm aware of and might not even work.
A smaller auger should penetrate easier, if you can live with the smaller hole.
My two cents, anyway.
Ron
/ More Post Hole Dig Advice #3
<font color="blue"> Would using a 6 inch auger to do an initial hole (pilot hole) and then using the 12 inch auger make the job any faster?</font>
Perhaps some of the more experienced diggers will chime in, but I'd think this could cause a problem since the 12 inch auger point would have nothing to dig into.
/ More Post Hole Dig Advice #4
I actually did a bit of this for a totally different reason. I was planting trees. I had a 9" auger on the tractor, my neighbor had my 12" auger in his locked garage and he was out of town. I drilled the holes with the 9" bit. A week later I went back to some of the holes that Ihad previously dug, but had not planted, this time with the 12" auger bit. The 12" auger did dig into the holes, but it sort of wobbled and I had a harder time making a straight hole. As I was planting trees, I was not really concerned about perfectly straight holes anyway, but it was a bit harder to do. But it did dig right in.
Well.....sounds like I will be stuck putting water in the initial hole and just wait....then go at it again.....
Thanks for your advice gentlemen.
Alex
/ More Post Hole Dig Advice #6
i have found, if you will take a 15-20ft section of pipe, and secure it along the top of the arm that holds the phd, so it sticks way way way out past and away from the digger, you can put some weight on the end of that pole and the digger will dig much much better...
heehaw
/ More Post Hole Dig Advice #7
heehaw,
I have saw the extended pole method used on diggers, but I bought me some cast weight to use on my digger. I need to weld a bracket on for the weights. I don't use my digger very often, because I have a Danuser post driver that I use mostly.
/ More Post Hole Dig Advice #8
i think, and it sure hurts when i do..but the further out from the digger you can put the weight, the better it works, so less weight is needed..just stay way clear of the drive shaft and the auger.
heehaw
/ More Post Hole Dig Advice #9
Not to change the subject to much. But are auger connections to the gear box generally universal. In other words do you need to get augers from the manufacture of your PHD to fit.?
/ More Post Hole Dig Advice #10
<font color="blue"> But are auger connections to the gear box generally universal.</font>
No. I've seen augers that use one bolt to attach to the output shaft, two bolts at right angles, round shafts, and hex shafts.
<font color="blue">In other words do you need to get augers from the manufacture of your PHD to fit? </font>
No. I have a Leinbach PHD and bought an auger at Tractor Supply. I just had to measure the output shaft as well as the location of the mounting bolts.
/ More Post Hole Dig Advice #12
For which application/when to use 6" auger? or 9"? or 12"? I'll have a post hole digger soon, but didn't decide yet which auger to buy. 12" is for old/grown trees? 9" doesn't do the same work? For fences, I guess 6" is enough?
/ More Post Hole Dig Advice #13
I have a small John Deere and use a Leinbach PHD with a standard 9 inch auger. Most of the time it works fine; however, we do have some areas on our place with limestone or caliche and the auger just sits and spins. Sometimes I do put water in the hole, but that's a slow process. I've discovered that if I pull the auger out and use a bar with a chisel blade to loosen up things in the bottom of the hole, the process is faster (also more strenuous). I don't have to loosen up everything in the hole--just enough on one side so that one of the blades can dig in. I find that I can usually get down about four inches at a time doing this. Fortunately, I usually don't have to do the entire hole this way--just a few inches. The bar also works well to break up rocks I encounter. The dealer carries augers with more agressive serrated blades, but I was too frugal to spend the extra money,
/ More Post Hole Dig Advice #14
Nomad,
After putting in 230 fence poles I can tell you what size auger works best. A 6" bit works fine for 4x4's and landscape timbers (although I don't use the timbers for posts, I've seen some folks that do). A 9" bit works fine for 6x6's. As you said, the 12" bit is good for doing trees.
I recently finished putting up a run-in for our horses. I built it like a pole barn and used my auger to drill all the post holes.
/ More Post Hole Dig Advice #15
</font><font color="blue" class="small">( I've discovered that if I pull the auger out and use a bar with a chisel blade to loosen up things in the bottom of the hole, the process is faster (also more strenuous).)</font>
A tool that can make this easier for you is an air chisel. I had to dig a shallow trench this fall by hand across the driveway, and the drive was about 12" thick of crushed stone, compacted over the last 100 years. Using the air chisel, I could loosen a layer of the stone, and the just shovel it out. Wash. Rinse. Repeat.
If you have any kind of a portable air supply, this could work for you. It would be much easier than using a manual chisel bar.
Dave
/ More Post Hole Dig Advice #16
Alex,
My auger has a cast or forged point mounted in the end of the central pipe that acts as a pilot for the larger diameter. The end of that point is a small bullet nose rather than a proper cutting edge. When the ground is normal, that bullet nose can just wallow its way down but in hard, dry clay, it won't penetrate. I would like to sharpen the end of it if I could find another point as a backup, just in case. If yours is like this one, you might try finding a way to drill a small hole the diameter of the pilot. Maybe one of those tiny augers you run in a drill. Then, I think the big auger would cut great if you could get the pilot to follow the pilot hole.
John
/ More Post Hole Dig Advice #18
Wroughtn harv,
As far as the fishtail goes, if its obvious to two guys off the street, such as ourselves, why wouldn't it be obvious to the manufacturer? I bought this one lightly used so that bullet nose was made that way at the factory.
John
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2013 Freightliner...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
AgCo Console 1 Monitor (A63117)
AgCo Console 1...
2001 John Deere 1770 Planter (A63111)
2001 John Deere...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
