More Newbies
/ More Newbies
Yep, when you put it that way, it's not very intimidating. But when I read woodlandfarms 'first year report', I say 'huh?' I have NO idea what most of that stuff means!
I can't wait to get it here just so I can stare at it for awhile.
Brad and I have also been having the 'project list obsession sleep disorder' now. The good news is that now when we see a nagging project that has gone undone for years, instead of feeling bad and overwhelmed, we get excited about how fast and easy it's going to be to get it done with the PT.
We spent yesterday cleaning out the garage and getting everything up off the floor to make room for attachments. Brad wants to build some racks on casters to hold implements double-decker style. He has read some posts about other people building heavy-duty shelving for this purpose.
I am not looking forward to all the repairs, trouble-shooting, and maintenance. But since we knew about it going in, it will be that much less aggravating, I hope.
Thanks for the welcomes, everybody.
Valjo
/ More Newbies #12
A caution on shelving for implements...
When putting an implement up on a shelf with the loader arms, be very careful. The unit has power down. That means you can apply hydraulic pressure in the downward motion to the loader arms. You can bring the weight of the entire tractor to bear down on an implement with a simple slip of the joystick. It is very easy to bring down or damage the shelving, so just be careful.
My advice for any new owner is to take lots of hours to get used to it. Drive slow, stay away from the house and cars, etc... it takes a few hours to get used to steering with articulation. It is kind of like steering a slinky from the middle. When you are sitting completely still and turn the steering wheel, the unit can swing an implement a couple feet to each side without going forward or backward. So, take it out into a clear area, play around with it. Make yourself an obstacle course and practice.
#1 rule is don't travel with an implement held up high, especially on any hils. Only raise the implement as much as needed to clear the ground. Especially buckets full of heavy material. This applies to all tractors, not just the PT.
/ More Newbies #13
I'm pretty new too .... I'll be learning the PT with you and your other half. After reading your list of attachments, now I don't feel too bad about picking up yet one more attachment when I go to Taxwell tomorrow.
/ More Newbies #14
To second MR's comments on safety- I agree 100%.
Go slow in the beginning, (always?) and read the tips here on how to get used to the treadle. It works great, but it is easy to over compensate. I drive with my toes on both treadles for better recovery from operator goofs. (or bumps).
If you are on slopes, I highly recommend that you get at least one inclinometer, preferrably two. They are invaluable in learning how to use the tractor and as a warning for when you are getting the tractor into areas that are unsafe.
They're great machines, and we have found them very easy to use, more so than standard tractors, but you do have to get used to the benefits and repercussions of articulated steering. (e.g. the tractor turning on a curve, but the implement turning well outside of it).
Have fun,
Peter
/ More Newbies #15
Remember that my tractor was used when i bought it. I was intimidated to say the least but it is a breeze to operate, and an amazing piece of equipment. it is fairly easy to work on, and you have a HUGE source of info here as well as from Terry at the factory.
Make sure you park your cars far away and do not drive near the house nor attempt to park it and put away implements in the first week. It drives like nothing you have ever driven and you have to think differently.
When backing up, steer the rear. It makes no sense what I am saying now but it will when the tractor arrives.
Watch for trees on slopes. There is a thing called Tree Wrap that we all experience. I had to cut down 3 trees to get unstuck. It is worse on the 1850 with dual wheels but you can still do it easy with singles.
So what is the list of things to do? Got pictures?
/ More Newbies
LOL!!! LOL!!!! "Stay away from the house and cars" LOL!!! Yeah, from my tiny experience playing around in Tazewell, I understand this advice, hee hee. I will do that, thanks for the reminder, you guys. I'm still sitting here giggling about what I could accidentally do to the house and cars. I wouldn't have thought of that. I would like to hear more about "Tree Wrap". Is the PT stuck because it is bent around the tree on the uphill side of the tree? Thanks for the tips!
/ More Newbies
Thanks for the advice, MR. I'm all ears.
/ More Newbies
Have fun tomorrow!
/ More Newbies #19
Do a quick search in the forum on it. Both Woodlandfarms and Mike OConnor have posted proof, I mean photos. :)
All the best,
Peter
P.S. My own version was to get the PT stuck just above a retaining wall dropoff while trenching. I was watching the trencher, and didn't realize the PT was digging itself in. Presto, I had dug one rear tire in deep enough to raise the front off of the ground. The PT waggle wasn't an option because of the dropoff. (well, I tried, and it made a bad picture worse.) Two and half hours, many rocks, and lots of work with a farm jack, and I was able to creep the PT out of its self made jail.
/ More Newbies #20
I forgot... Go by a spinner nob. A nice one. One that wraps around the spoke of the wheel and the wheel, not just the wheel.
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
Topcat ECSSSTG200 (A60463)
Topcat ECSSSTG200...
CFG Industrial 680 QA Hydraulic Hummer (A60463)
CFG Industrial 680...
