More Musings and Random Ramblings
Status
Not open for further replies.
   / More Musings and Random Ramblings #51
That doesn't compute! :confused3:
When we end the hot summer day in the house we want to be cool.
When we end the cold winter day in the house we want to be warm.
Why else would we have climate control in the house?
   / More Musings and Random Ramblings #52
Gotcha... I guess I didn't realize you could have your heat setting warmer than the cool. Never given it much thought.
   / More Musings and Random Ramblings #54
Awww,, gotcha.
We never leave our system on auto. We select heat or cool. This choice is based on advice from our installer.
If you choose to set your system on auto, you'll have the same temp for both.
   / More Musings and Random Ramblings #56
Any "thing" can be talked about....IF you have and can choose the right words...!
   / More Musings and Random Ramblings #57
Awww,, gotcha.
Our heat set to 62 (summer), 66 (winter)... A/C 78. Augment with a gas fireplace in the living room.
My heat is set to "Outside Temp" in summer and 50 in winter... augmented by my wood stove.
   / More Musings and Random Ramblings #59
Awww,, gotcha.
I don't believe that's true, at least not with all thermostats. Our new system came with a Nest, smart thermostat. It specifically calls for different temperatures between the heating and cooling cycles. I believe my previous one (non-Nest) also called for different temperatures.
   / More Musings and Random Ramblings #60
It should NOT be up to the tStat or the company that makes them to determine any of the setting ranges. That should be determined ONLY by the end user and the equipment they have installed.
Status
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Informational Lot - Shipping (A55315)
Informational Lot...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
large capacity skid steer bucket (A56857)
large capacity...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
Hose Reel (A55758)
Hose Reel (A55758)
