More Musings and Random Ramblings
Status
Not open for further replies.
   / More Musings and Random Ramblings #51
That doesn't compute! :confused3:
When we end the hot summer day in the house we want to be cool.
When we end the cold winter day in the house we want to be warm.
Why else would we have climate control in the house?
   / More Musings and Random Ramblings #52
Gotcha... I guess I didn't realize you could have your heat setting warmer than the cool. Never given it much thought.
   / More Musings and Random Ramblings #54
Awww,, gotcha.
We never leave our system on auto. We select heat or cool. This choice is based on advice from our installer.
If you choose to set your system on auto, you'll have the same temp for both.
   / More Musings and Random Ramblings #56
Any "thing" can be talked about....IF you have and can choose the right words...!
   / More Musings and Random Ramblings #57
Awww,, gotcha.
Our heat set to 62 (summer), 66 (winter)... A/C 78. Augment with a gas fireplace in the living room.
My heat is set to "Outside Temp" in summer and 50 in winter... augmented by my wood stove.
   / More Musings and Random Ramblings #59
Awww,, gotcha.
I don't believe that's true, at least not with all thermostats. Our new system came with a Nest, smart thermostat. It specifically calls for different temperatures between the heating and cooling cycles. I believe my previous one (non-Nest) also called for different temperatures.
   / More Musings and Random Ramblings #60
It should NOT be up to the tStat or the company that makes them to determine any of the setting ranges. That should be determined ONLY by the end user and the equipment they have installed.
Status
KMC 70Z7 WHEEL LOADER (A52709)
KMC 70Z7 WHEEL...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
1980 Gleaner F2 with heads (A55315)
1980 Gleaner F2...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56435)
2019 RAM 5500...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
