Backhoe More Loose Sub-Frame Bolts LB1914 Backhoe
   / More Loose Sub-Frame Bolts LB1914 Backhoe #1
Maineiac
Maine
LB1914
This is just to mention again that folks should check and re-check their sub-frame bolts. I have about two hours into my new KB2364 hoe on my LB1914. After reading TBN, I decided to check the bolts and sure enough, some were pretty loose. I intend to Loctite and impact wrench them into place very soon.
   / More Loose Sub-Frame Bolts LB1914 Backhoe #2
I hate to ask this but what bolts are people finding loose? I have been checking my bolts over the last 80+ hours and not seen one loosen up yet. I just want to make sure I am not missing something when I am checking the bolts as my BH has stayed on my tractor so far all but about 1.5 of my operating hours.
   / More Loose Sub-Frame Bolts LB1914 Backhoe #3
Stephen,
My bolts would work loose where the backhoe and subframe come together and the bars that angle down from the backhoe to the subframe.
   / More Loose Sub-Frame Bolts LB1914 Backhoe #4
I checked mine the other day and there were two that I got little movement on, but there was no evidence that anything was moving that shouldn't have been. I have about 50 - 60 hours on my backhoe so far.
Steve
CK20J TLB
   / More Loose Sub-Frame Bolts LB1914 Backhoe #6
Here is a pic of my BH as it was being readied for installation. Note the red circles around the support arms which is where they loosen, causing the backhoe to have a lot flex as one is digging.
John
   / More Loose Sub-Frame Bolts LB1914 Backhoe #7
</font><font color="blue" class="small">( TIGHTEN UP PEOPLE ! )</font>
No longer any need, I welded it solid /forums/images/graemlins/tongue.gif
   / More Loose Sub-Frame Bolts LB1914 Backhoe #8
Well, I saw the thread and checked the bolts on my KB2365 and found none loose /forums/images/graemlins/smile.gif. I'd guess-ti-mate I have about 100 hrs. on the BH.
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
