Backhoe More Loose Sub-Frame Bolts LB1914 Backhoe
   / More Loose Sub-Frame Bolts LB1914 Backhoe #1
Maineiac
Maine
LB1914
This is just to mention again that folks should check and re-check their sub-frame bolts. I have about two hours into my new KB2364 hoe on my LB1914. After reading TBN, I decided to check the bolts and sure enough, some were pretty loose. I intend to Loctite and impact wrench them into place very soon.
   / More Loose Sub-Frame Bolts LB1914 Backhoe #2
I hate to ask this but what bolts are people finding loose? I have been checking my bolts over the last 80+ hours and not seen one loosen up yet. I just want to make sure I am not missing something when I am checking the bolts as my BH has stayed on my tractor so far all but about 1.5 of my operating hours.
   / More Loose Sub-Frame Bolts LB1914 Backhoe #3
Stephen,
My bolts would work loose where the backhoe and subframe come together and the bars that angle down from the backhoe to the subframe.
   / More Loose Sub-Frame Bolts LB1914 Backhoe #4
I checked mine the other day and there were two that I got little movement on, but there was no evidence that anything was moving that shouldn't have been. I have about 50 - 60 hours on my backhoe so far.
Steve
CK20J TLB
   / More Loose Sub-Frame Bolts LB1914 Backhoe #6
Here is a pic of my BH as it was being readied for installation. Note the red circles around the support arms which is where they loosen, causing the backhoe to have a lot flex as one is digging.
John
   / More Loose Sub-Frame Bolts LB1914 Backhoe #7
</font><font color="blue" class="small">( TIGHTEN UP PEOPLE ! )</font>
No longer any need, I welded it solid /forums/images/graemlins/tongue.gif
   / More Loose Sub-Frame Bolts LB1914 Backhoe #8
Well, I saw the thread and checked the bolts on my KB2365 and found none loose /forums/images/graemlins/smile.gif. I'd guess-ti-mate I have about 100 hrs. on the BH.
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
Toro Groundsmaster 3500-D Rotary Mower (A56857)
Toro Groundsmaster...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3.75 Ton Crane Service Truck (A55973)
2017 Ford F-550...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2008 KENWORTH T300 (A58214)
2008 KENWORTH T300...
