More horsepower? CT225
   / More horsepower? CT225 #1
outsidezion
Zion Grove, PA
Bobcat CT225, Case 444,
Love my CT225 with backhoe. It is the perfect, all-around homesteader size. It plows snow, hauls firewood, plows deer plots, lifts logs..... and is nimble on my 93 acres.
Yet, it would be bomber if I could squeeze another 5 hp out of it. Is this possible?
I came from a Kioti DK40 which I loved. That felt like a big tractor in comparison and I do not regret the downsize but sometimes miss the power.
   / More horsepower? CT225 #2
Anything is possible. What year is your tractor?
I believe its a 2009. It's not that HP is inadequate. And the hydraulics are fantastic. But it does seem with the hydrostatic, it could have been designed better for another 3-5 hp.
   / More horsepower? CT225 #4
I have the same tractor. I know what you mean. I have to drop to low range due to lack of power a little more than I would like. I think a 235 is probably perfect, but I have never used one.
   / More horsepower? CT225 #5
Trade up in size.
CT235 appears to be more HP in the same chassis.
CT120 21 hp 2008 - 2013
CT122 22 hp 2008 - 2013
CT225 27 hp 2008 - 2013
CT230 30 hp 2008 - 2013
CT235 34 hp 2008 - 2013
CT335 38 hp 2008 - 2013
CT440 41 hp 2008 - 2013
CT445 45 hp 2008 - 2013
CT450 49 hp 2008 - 2013
   / More horsepower? CT225 #6
Talking about more hp is always cool. I was under the impression that the early ct 225 only had 24.5 hp or something like that. I may be wrong on that but a vin check on the motor should verify. I did see the posted chart so I'm second guessing my self now. It would be good to confirm your current hp first But if it is the motor with 27 hp I don't see where upping hp will help much with drive power because the hydro relief is set at a set pressure and it is not adjustable with out modification. (Assuming we are talking hydro trans)the ct 225 and 230 share same setting. the ct 235 has a higher hydro setting. Where you would notice extra hp is at the pto.
As a side note the kioti version of the 2011-2013 model(and other years but not sure starting year) have the same motor with same displacement just one letter different on model but the kioti shows 28 hp. So my thought is it would be hard to notice that 1 hp but makes me wonder how did they achieve the extra hp ( if it really is different) and is there more to be had?
Yeah, I was hoping there was something like a set-screw or an emissions tuning setting that could be tweaked. :)
   / More horsepower? CT225 #8
Just remember that everything on the tractor is designed for the horsepower it came with. What happens to the hydraulics, gears, loader, hoses when you push 118% of rated power through them. Will they hold up? Will they fail earlier? I don't know. Then again, in the pictures I've seen it looks to be about the same physical size as my Kubota and it's 33HP so maybe the CT225 engine is undersized.
   / More horsepower? CT225 #9
I have seen guys turn up fuel pressure until just before you start to see black smoke on larger tractors with some impressive hp gains. I'm thinking that this is how Kioti achieves the different hp ratings of this motor in different tractors. But I'm just guessing and not a mechanic. It would be cool to hear about someone's experiences and results that tries it.
   / More horsepower? CT225 #10
I think all the components are the same as the 235 which has 34 hp. I would think you should be good as long as you did not go above that.
   / More horsepower? CT225 #11
No adjustment for the rack for the application. You cant turn it up. If you have a fuel injection shop near you you can have the pump bench tested and set up. I've see quite a few of these pumps not set up correctly(delivery valves)and delivering different amounts of fuel to each injector.
   / More horsepower? CT225 #12
That's interesting is that generally something that is difficult or expensive to have done?
   / More horsepower? CT225 #13
I can change the pump out in about 2 hrs. A novice tech can do it with the service manuel. Not sure what the shops in your area charge. Flate rate in our are area is about $75 depending on the pump.
   / More horsepower? CT225 #15
OR as the chassis is the same for the 235, find a used larger engine and drop it in. Should be a direct bolt fit. But before putting it in, get it tuned up. Many of the HP tricks that are used on gas work on a diesel, especially air flow tricks.
   / More horsepower? CT225 #16
Check out everything attachments, I seem to remember reading that Ted tweaked a tractor earlier this year .
   / More horsepower? CT225 #17
Just remember guys you can not turn Bobcat injection pumps up. The stroke of the rack is some what fixed.It is connected to the throttle/governor via a spring. I would not mess with the throttle adj. especially if you have a lot of hrs. on the unit. Some injection pumps have a stop on the rack. This is what is being adjusted in the posted video. Bear this in mind and I've seen it happen. Its just like the plumbing in your house and you have low water PSI. You call the plumber and he turns up the PSI. A hour later you start springing leaks and the kamode is running. With diesel engines they usually come apart or start making horribly noises.
   / More horsepower? CT225 #19
There's always The option of adding a turbo. I have read a couple of threads on here of guys that have done it two other tractors and they seem to have been happy with it. Plus it sounds kind a like a cool project. I'm happy with the power of mine too but who doesn't like more power?
   / More horsepower? CT225 #20
What RPM are you running at?
Kubota M6 131 HP
Kubota M6 131 HP
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2021 Polaris Ranger 570 EFI AWD Utility Cart (A59228)
2021 Polaris...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
UNUSED IRANCH 38" MINI LAND LEVELER (A60432)
UNUSED IRANCH 38"...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
