TillerofdaEarth
Owners manual states that...When PTO selection switch is placed in "AUTO" position, if you press the main clutch pedal or the "hydraulic position control lever" moves up the arranged position during operation, the PTO will not rotate.
Any dealers know what the "Arranged" position is?
The reason I ask is, that with my rotary mower hooked to the 3 point, the only way the "Auto" position of the PTO will work, is if I back over a ditch, allowing the mower and 3 point arms to drop to their lowest point, the PTO will then engage. Raise the 3 point just a touch and the PTO disengages.
I don't understand the logic of this set up. The "AUTO" position is basically worthless for pulling a mower, snow blower or running a post hole digger, if it will only engage with the lift arms at their lowest position. I could understand, if the PTO disengaged as the lift arms approached or reached full lift position.
The "independent" PTO selection works fine.
I thought maybe there was a switch on the 3 point lift cylinder that could be adjusted, but, my dealer spoke with a Montana service rep who told him this is how the "AUTO" PTO works on the larger "CUT's".
Any other 5740 operators noticed this as well?
I guess the "AUTO" position is only good for running some kind of PTO driven pump, with the lift arms have to set to their lowest position, where they would interfere with any drawbar pulled equipment..... /forums/images/graemlins/confused.gif
