Molded bungee hooks, so that's how they make those.
   / Molded bungee hooks, so that's how they make those. #1
QRTRHRS
Elite Member
The Bluegrass State
None at this time.
I like to repurpose elastic bungee hooks. I usually buy the one's with wire hooks but had this one around with the heavy molded plastic hook covering where the elastic fastens. It was worn out so I took a saw to it to see what was what. Not worthy of much.
With the wire hook type, if I get a weak spot, I cut the elastic and secure it with a wire staple just like new. I use the poly/wire for electric fencing. I save the old wire hooks and as demonstrated in my photo, loop the wire rope through instead of gate handles for temporary fencing, etc.
   / Molded bungee hooks, so that's how they make those. #2
I keep a supply of those hooks around:
Like you, I cut out the weak spot in the damaged bungee and put a hook on either end to make two shorter bungees. I hook them together if I want the same original length.
Bungees used to be cheap as dirt, but like everything else, the prices are going up. Makes perfect sense to repurpose or repair them.
   / Molded bungee hooks, so that's how they make those. #3
When I actually ran a lot, I used to find bungee cords and S-hooks on the road constantly. Unfortunately, many of the bungee cords were either broken, or missing a hook.
So I would pick them all up, throw away the broken bungees and keep the hooks for the ones that were missing. I sill have a big enough collection that I may never need to buy any more....
While driving one day, I started seeing rubber bungee's on the road. I came up behind a flatbed that had several still hanging on his DOT bumper where had staged them at his last drop.
He was not too happy with himself when I told him over the CB.
2016 BOMAG BW 177D5 SMOOTH DRUM ROLLER (A52707)
2016 BOMAG BW...
2014 Ag Spray Schaben Sidedresser (A57024)
2014 Ag Spray...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2005 Kubota L3130 (A53317)
2005 Kubota L3130...
CASE IH STEIGER 400 HD TRACTOR (A57192)
CASE IH STEIGER...
REFRIGERATOR / FREEZER COMBO (A57192)
REFRIGERATOR /...
