Moldboard Plow
/ Moldboard Plow #1
gwkyle
John Deere 5603
I am looking for a three bottom moldboard plow for a three point hitch. I have 180 acres of hayland to break up, half of it hasn't been broke up for 30 years. Any suggestions on a plow that could do this job.
/ Moldboard Plow #2
Hello gwkyle, welcome to TBN! Glad to see you posting. Hope you enjoy being a member of our community. :)
/ Moldboard Plow #3
Welcome to TBN.
If you have a big enough tractor to pull a 3-bottom plow, about any of them will work. Are you looking to buy new or used?? If used, keep an eye on craigslist, they seem to come up there pretty often, at least in my area.
/ Moldboard Plow #5
Here is a nice 3 bottom Oliver trip beam plow with coulters for $695. No major breaks or welds and the plows are not sprung. Ken Sweet
/ Moldboard Plow #6
Welcome.:thumbsup::thumbsup:
Remember the moldboards on a plow used for breaking sod are different than the ones used on cultivated land. :)
The normal ones do not turn the sod over properly and leave a pretty rough mess behind them. After discing the turned over 180 acres your back will not be happy.:)
Have you considered having it broke up with a chisel plough or heavy disc? It would require a much larger tractor than that to pull three bottoms.:)
/ Moldboard Plow #9
The mold board on a breaking plow is longer and has a gentler sweep to it so it does not break the sod strip and let it fall back in the furrow.:D
/ Moldboard Plow #10
180 acres with a 3 bottom moldboard.... Sounds like some sort of punishment to me. :D
/ Moldboard Plow #11
I had a set of John Deere 3 bottom plows a few years back that would not turn the sod completely over. I found they have moldboard extensions that bolts on the back of the moldboard with 2 bolts and they could be bent to make the sod turn more quickly and keep it from falling back in the furrow. They were made form 3/8 X 4 X 8 inch cold roll flat stock. Ken Sweet
/ Moldboard Plow #13
Picture of a sod breaking moldboard.:)
/ Moldboard Plow #14
What type of soil and how much trash on top?
By three point hitch are you looking at semi-mounted or fully mounted? I would expect semi-mounted to be far more popular than fully mounted.
Where are you located? This can and will play a factor in what you can find locally and what the price tag will be.
Rocky soil I would probably consider a spring reset plow VS trip beam.
Lots of trash models like the IH 700 or 710 have good ground clearance for trash.
Don't remember the model of JD hydraulic reset plows but I would avoid one of them.
good luck
Roy
/ Moldboard Plow #15
Thanks for the picture and explanation. Around here we have always used the same plows, didn't matter if it was sod or tilled ground with good luck. We added a curved trash board which seems to help flip the sods over, and also a good set of coulters to give a good slice. The btms aren't as swept back as the ones you have shown.
The best plows I have used were made by Oliver (or who ever made them for Oliver, White, and Ford) with spring reset trips.
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2019 GENIE S-40XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-40XC...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
24220 (A56859)
24220 (A56859)
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
