Mold Board - Potato Plow combo
   / Mold Board - Potato Plow combo #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I promised pix, and this is linked to another thread.
I bought this from Northern Tool. It is the NorTrac version. I got it with the potato plow then ordered the mold board for another $40.
I got worried that it would be cheap and lightweight but so far it has held up very well. Later this winter I am pulling electrical and such with it.
As for dimensions..... It is a class 1 plow. It is hooked up to my 3 pt adapter so don't get too confused.
The plow is 16" at its widest. The depth is adjustable by 4" on the stem. I have it in its lowest position which will board at 22" and potato plow at 18" in the extended position. Clearly knock off 4" for moving the shank up.
As for use, I have yet to cut a straight line. It is really due to the Power Trac and its articulated center and the fact you are driving backward. But it works, and works pretty well. I have been digging ditches for runoff and so far am very happy.
Carl
   / Mold Board - Potato Plow combo #2
Great pics. Thanks for the measurements too.
   / Mold Board - Potato Plow combo #3
Carl,
I see a potential for damaging the 3pt arm if you hook on something solid.
   / Mold Board - Potato Plow combo #4
Looks good I am curious about the attachment to pull electrical have you done any of that yet and where did it come from if thats how you planned to do that?
I have toyed with buying a TSC plow/chute they sell for their middle buster its only 60 bucks and put it on my KK MB to do the same thing so just wondering how well it works.
   / Mold Board - Potato Plow combo #6
You can use that same shank with no plow, and weld a chain and bullet noses device for pulling wires. The purpose of the bullet is to expand the hole for the wire, and makes for less tension on the wire.
I have done the same thing using the bullet on the chain with a 3/4 galv pipe and threaded a PVC fitting into the back of the bullet and pulled a 100 ft of PVC pipe already glued. When you got to the end of the pull, you were done, except to finish out the PVC setup.
You can also pull several items at the same time.
If you think you might have roots, do a digging run first, and if clear, restart and bury the wire, PVC, black poly, wire, cable, etc.
http://youtu.be/7Ntj0YLrcng
This is the pipe puller I am most impressed with.
http://youtu.be/jIeEc8sFhIE
One of the guys on TBN built this.
   / Mold Board - Potato Plow combo #7
The home built one at the bottom looks like the one I was thinking about buying JJ. :thumbsup:
I wish I would have bought the dang thing when I knew where it was I cant find it at TSC or anywhere right now it just vanished from the search engines???
Man it was slick it was a radiused chute that bolted to the back of a subsoiler (MB with 2" shank) on a pivot with a curved tubular split pipe you laid the 1/2" black pvc was the size it used (or wire is what I planned on doing) closed the lid pinned it and go to work.
That would have saved me and anyone else that was wondering how to do it a lot of time and effort building one and it was only 60 bucks I think well ya snooze ya loose I always say darn it. :confused:
I think mine was on sale for $120 and then another $40 for the moldboard.
I doubt it could be had for $60 even used.
Now here comes the toughest quetion
Is it easier to pull the pipe in or fold it in with the device you listed.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
(4) 6 LUG GMC TIRES & WHEELS (A51248)
(4) 6 LUG GMC...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
