Mods, Round 1
/ Mods, Round 1 #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
With the steering out until tomorrow, I got on all of my mods...
First up was to open up the oil cooling baffel. It is Part 1 of a 2 part idea. From what I understand you do not want to restrict the outflow of air from the cooling. PT's 1850 engine is heavily restricted. The opening being just half the surface area. At first I was going to cut up some tin and make a whole new baffel, but then I saw Alta's mod and it gave me an idea. In my head opening the sides allows the air to stay in the engine compartment. Also, I cannot weld yet (have welder, just no real ability). So I drilled a hole 1.5" down the side plate, and then took a peice of 1/2" gas pipe and cut a 1.5" spacer.. 2 bolts and $3.00 later....
Part 2 of the idea is figuring a quick way to open the bottom plate to allow cleaning. Also, I have noticed some air blowing up by the injectors, I figure if I plug those holes up I should force more air through the cooler...
/ Mods, Round 1
Next was the Tiny Tach. $65.00. On the 1850 I nearly did not have enough cable so order 3 extra feet...
I did a poor job of finish work on the installation. I could not cut the dash plate good enough, so I surface mounted it. It works quite nicely and now I can guage the power I am at much more precisely. Also it has 3 timers so I know for sure when to do my 8 and 50 hour maintenance...
/ Mods, Round 1
Mirrors and Lights. Mirror was out of JC Whitney and I just drilled two small holes through the roof (not the rops) to install... It is kind of hard to look at it instead of turning around but I am sure I will start using it more. Lights were cheapies from Gemplers. I think if I where to do it again I would go Ksimolos way, I think these pull too many amps and there are more efficient lights to be had...
/ Mods, Round 1
Neighbor scarers. One of those I just had too's. Notice my foam head bumpers? They are completely trashed after just one week.
I just have to figure out a cup holder. Anyone know where I can get those old style basket ones that swing around? My current holder does not work on the slopes...
/ Mods, Round 1 #5
Carl,
You want a gimbled holder. Try West Marine, or any good chandler.
All the best,
Peter
/ Mods, Round 1 #6
I have an insulated cup with a magnet in the bottom that will hold it horizontal.
A search for Chalkley Cup may get you a link to it.
/ Mods, Round 1 #7
Careful with those bolts. They are all that holds the oil cooler metal-to-metal seal to the engine. I found out via an inadvertant oil change.
/ Mods, Round 1
I had remembered hearing of your tale before.. So I did not bump the thing when I removed it, and the 1/2" pipe works as a great hold down (so far, have yet to drive it without the steering).
Carl
/ Mods, Round 1 #9
Good deal.
Raising the defelector over the engine oil cooler will help, it made a difference on mine.
Whats the PN of that Tiny Tach?
I love the skull on the hyd joy stick, reminds me of the drill outfit in the movie "Armageddon".
-=Billy, out.
/ Mods, Round 1
Dropped my temp by at least 20 degrees. I am going to fill up some of the cracks with aluminum foil (where the injector lines run out) as there is a lot of air lost there...
You will totally love the tiny tach....
Tiny-Tach: Diesel Tachometers
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
FARMALL 140 TRACTOR (A63291)
FARMALL 140...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
Hydraulic Stump Bucket Mini Skid Steer Attachment (A61572)
Hydraulic Stump...
(3) TRUCK RIMS & WELL PUMP (A63291)
(3) TRUCK RIMS &...
Caterpillar 613C Wheel Tractor Scraper Service and Parts Manuals (A63117)
Caterpillar 613C...
