Modifying a Bale Spear?
/ Modifying a Bale Spear? #1
teg
Super Member
nowhere
s
I want to lighten a Bale Spear, it weighed 250 lbs. I unbolted the old brackets and would like to weld new bottom brackets that will lower the overall weight by 100 lbs. As a side bonus, I can bring the hook up points 2 inches closer to the tractor (when you talk about a half ton, that adds up, (I think :confused: ) ).
Questions, Will it be strong enough? and does it matter which way the brackets go? I know I can reverse the pins later but would like to know if one way is stronger, my gut says to the left (But if it's not welded good - it really doesn't matter which way, eh? :D).
(I have a question in the attachment section on if I should just sell this but I would still like to know if you guys think welding the brackets a certain way works better or not).
/ Modifying a Bale Spear? #2
I usually mount mine with the pin pointing out because my draft links swing out freely. It makes it a little easier to hook up without adjusting the sway links.
I have bent a few angles mounted in this configuration however a small gusset, maybe 2x2 or 3x3 welded on the bottom or top of the angle should give it all the strength you need.
CHECO GREASE UNIT (A68842)
CHECO GREASE UNIT...
2020 CATERPILLAR 289D3 SKID STEER (A65056)
2020 CATERPILLAR...
2015 Chevrolet Silverado 2500HD Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
KOMATSU D31PX Blade / C-Frame (A68134)
KOMATSU D31PX...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
ALLMAND  MAXI LITE 2 V (A67714)
ALLMAND MAXI LITE...
