Modify FEL stick
/ Modify FEL stick #1
Rustyrat
Maine
JD 2305 tlb
As I move in the seat of my JD 990, my fat arse tends to hit the stick for the FEL. I know, I could do something about the fat arse, but I think modifying the stick might be quicker. Does anyone have any suggestions on bending the stick a little in a couple of spots? There seems to be plenty of clearance.
/ Modify FEL stick #2
Heat it up, bend it to suit fat arse then repaint...no problems:thumbsup:
/ Modify FEL stick
Thanks Kennyd. I may get brave and give it a shot this weekend.
/ Modify FEL stick #5
Get some pictures please-both before and after
of the finished stick..not the fat arse:):)
(come on now, I know you were all thinking it)
/ Modify FEL stick #6
Worked fine on my 4300. Was my fat leg that usta hit the stick. I just made sure that the flame didn't get near the plastic fender. Bent the stick at the same places of the original bends, only moreso.....
Now if I could only design an electric heater for that cold plastic knob when moving snow...
/ Modify FEL stick #8
Its called a CAB !!!
/ Modify FEL stick #9
I had the same problem on my previous 4115, 4500, 2320, 2520, and 2 4120's. I seriously thought about bending all the joysticks but never did. I now have a 4720 CAB and it is mounted up higher on the console so I dont have to worry about it now. Only problem I have now- I am 6'6 310lbs and so getting in and out of the cab can be challenging at times but I will deal with it...:laughing:
/ Modify FEL stick #10
They are adjustable, so why not just move it over a little bit?
/ Modify FEL stick #12
The one on my JD2520 is, I adjusted it to fit my new Suspension seat, because the new seat was way higher and its great now.
Its all a bunch of little jam nuts on the ball joint linkages at the bottom of the stick. Took a few minutes, but its perfect now. :thumbsup:
/ Modify FEL stick #13
No adjustment on my 2010 2520 that I can see. Sure wish there was. My knee hits it and tilts the bucket down whenever I turn around.
/ Modify FEL stick #14
Its down by your feet. I think you need to remove a plastic cover so see the adjusters. I'm not by mine, or I'd look.
Its literally on the bottom of the stick, so just follow it down with a flashlight and have a look at the bottom of it! :thumbsup:
/ Modify FEL stick #15
When I curl the bucket in on my 755 the stick hits the seat. It definitely needs the hot wrench.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
ROTARY SCYTHE (A63291)
Great Dane Van Trailer (A63689)
Great Dane Van...
INTERNATIONAL 490 - 21' DISC HARROW (A63291)
INTERNATIONAL 490...
iDrive TDS-2010H...
213324 (A64279)
213324 (A64279)
