Modify FEL stick
/ Modify FEL stick #1
Rustyrat
Maine
JD 2305 tlb
As I move in the seat of my JD 990, my fat arse tends to hit the stick for the FEL. I know, I could do something about the fat arse, but I think modifying the stick might be quicker. Does anyone have any suggestions on bending the stick a little in a couple of spots? There seems to be plenty of clearance.
/ Modify FEL stick #2
Heat it up, bend it to suit fat arse then repaint...no problems:thumbsup:
/ Modify FEL stick
Thanks Kennyd. I may get brave and give it a shot this weekend.
/ Modify FEL stick #5
Get some pictures please-both before and after
of the finished stick..not the fat arse:):)
(come on now, I know you were all thinking it)
/ Modify FEL stick #6
Worked fine on my 4300. Was my fat leg that usta hit the stick. I just made sure that the flame didn't get near the plastic fender. Bent the stick at the same places of the original bends, only moreso.....
Now if I could only design an electric heater for that cold plastic knob when moving snow...
/ Modify FEL stick #8
Its called a CAB !!!
/ Modify FEL stick #9
I had the same problem on my previous 4115, 4500, 2320, 2520, and 2 4120's. I seriously thought about bending all the joysticks but never did. I now have a 4720 CAB and it is mounted up higher on the console so I dont have to worry about it now. Only problem I have now- I am 6'6 310lbs and so getting in and out of the cab can be challenging at times but I will deal with it...:laughing:
/ Modify FEL stick #10
They are adjustable, so why not just move it over a little bit?
/ Modify FEL stick #12
The one on my JD2520 is, I adjusted it to fit my new Suspension seat, because the new seat was way higher and its great now.
Its all a bunch of little jam nuts on the ball joint linkages at the bottom of the stick. Took a few minutes, but its perfect now. :thumbsup:
/ Modify FEL stick #13
No adjustment on my 2010 2520 that I can see. Sure wish there was. My knee hits it and tilts the bucket down whenever I turn around.
/ Modify FEL stick #14
Its down by your feet. I think you need to remove a plastic cover so see the adjusters. I'm not by mine, or I'd look.
Its literally on the bottom of the stick, so just follow it down with a flashlight and have a look at the bottom of it! :thumbsup:
/ Modify FEL stick #15
When I curl the bucket in on my 755 the stick hits the seat. It definitely needs the hot wrench.
43024 (A59228)
43024 (A59228)
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
2012 International Prostar (A63118)
2012 International...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
207269 (A52708)
207269 (A52708)
