Modify Bottom Plow for SCUT?
/ Modify Bottom Plow for SCUT? #21
Funny how 3pt items mount, I have almost the opposite problem with a rotary mower, lifts high, but just barely goes low enough. I quess implements and tractor 3pts are not as universal as they tell us.
Since I am a visual learner, thought I'd throw in a fairly good video on how to set up and use the plow. It will give you some idea about what the gentlmen are trying to explain.
Leinbach 19-12 Bottom Plow, 3pt. Hitch Gardening, EverythingAttachments.com
That's funny - because that's the video I found on how to setup the plow.
For me, my lift arms are at full height to raise it above the ground. The video said they should be below horizontal. However, it didn't seem to effect the plowing any.
More important, was how they talked about the cutting edge needed to have full contact, and the plow leaning a little, but not too much forward. Most importantly, they also explained why.
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Kemp 3pt Wood Chipper (A60463)
Kemp 3pt Wood...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Mini rock grapples (A61567)
Mini rock grapples...
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
