Modify a QA blank to pickup JD loader attachments
   / Modify a QA blank to pickup JD loader attachments #1
dirtracer31
Lexington, TX
My neighbor has root grapple, for a JD standard loader, that we want to use on my tractor. My tractor has a SSQA loader. We have already pick it up with my tractor. The JD holding pins are wider and below the my QA plates. Thinking of making a blank plate that was tall and wide enough to use the JD pins? As anyone did this with any success? My concern is bending the plate were the pins come through.
Thanks
   / Modify a QA blank to pickup JD loader attachments #2
   / Modify a QA blank to pickup JD loader attachments #3
Something like this?
Adapter JD 200cx, 300-400-500 attachments 2 skidsteer loader
skidsteer_quick_attach__jd_200_300_400_500_loader_158
Yes something like that!
I was thinking of using a solid plate though.
Thanks I'll check them out.
   / Modify a QA blank to pickup JD loader attachments #5
Yeah a solid plate may work a little better, I'm sure you look a little and can find others out there too. Be a good thing to have if a guy had access to some JD style attachments.
   / Modify a QA blank to pickup JD loader attachments #7
Yes they do have a bunch of adapters and attachments, all there stuff I've seen is built tough.
UNUSED FUTURE MINI QUICK COUPLER (A57193)
UNUSED FUTURE MINI...
2015 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
