Model Advice
/ Model Advice #61
With a loader, near impossible to steer until you start moving, then easy - unless there's a lot of weight in the bucket.
With a loaded bucket use the loader to lift the front tires off the ground, spin the steering wheel to point where you want to go, set the tires down and start off.
No loader? No big deal but you learn to start rolling before steering. It becomes instinctive. My last heavy non-ps vehicle was a Wagoneer, and long ago an Oldsmobile same model as a CHP cruiser. Plus Ford pickup etc that felt lighter. it's not that difficult, after you learn to start rolling slightly before attempting steering.
Your wife shouldn't have a problem.
/ Model Advice #62
I agree with California, very difficult when sitting still. Slightly difficult with a load in the FEL bucket or lots of weights on front of tractor. Just like non power steering vehicles of years gone by, much easier with just a bit of rolling regardless of the load on the front. Add a spinner knob to help.
All that said, it is doable or no one would run a tractor without PS. Mine does not have PS and it is rarely an issue.
/ Model Advice
Good deal. I'm not paying what they want for a loader with a skid steer on hand already.
/ Model Advice #64
one more question I've been thinking about. What's the effort required to steer one of the non-PS models? Since the wife might use it, that's an important consideration. If it's too hard to steer she might not use it.
Good question. When I was in my 30s I had two tractors - one a Yanmar - with loaders and no power steering. You can do it.... I got the work done, but it sure wasn't easy.
Basically with a good load in the bucket steering is very difficult. Even if you can turn the steering wheel, you are putting a huge load on the steering gearbox. With any load in the bucket it was often necessary to stop, put the bucket on the ground, add some down pressure to lighten the front end, turn the wheels, then lift the bucket and proceed. Like I said, you can do it and so can she, but I ended up spending way to much time trying out various schemes to power the steering. All without real success.
Since I use the loader a lot just for chores, all our tractors since have had power steering.
Oh, WITHOUT A LOADER all the tractors I've ever drive steer just fine. In fact, they steer easily with one hand. No problem.
If your wife enjoys landscaping, planting things, and just general yard work and gardening ..... she would love a tractor with a small loader and power steering. She just doesn't know it yet. They are just so handy.
rScotty
/ Model Advice
rScotty
Something to think about for sure. Maybe a newer compact with a hst might be better. I think she could handle the power shift with a little practice but an hst is even easier. Gotta find some time to let her drive some.
/ Model Advice #66
Then there is A 3pt. scoop. What I use on the Ym2000 no power steering. Works really good. Fredricks has them. 275$ I think I seen. Believe it's the same make as mine, Lowery. Great for small chores. So extremely light a couple minutes to hook up. And then you don't have a FEL sticking out the front when mowing etc.. I have plenty of seat time on a JD. 5103 with a FEL.. 50Hp. It had a Frontier removable Bucket which stayed off.. One of the reasons the 2000 doesn't have a FEL. knowing what It can do. Had to move a large pile of dirt and wasn't nothing to it. Great to just hold and move things also Firewood Etc..
/ Model Advice #67
Am I losing my mind or aren't we on the vintage yanmar section?
I would agree. My Fredricks YM2610 just had a little over 1410hr on the meter when I got it. Tom mentioned they do not mess with the meter hours. That's like messing with a car OD. Each meter belongs to the tractor it came out of. I've just rolled it to 1706hrs last week. Not bad from summer 2014 till now. The hours really add up when the engine is at and above 2200rpm. BUT, I tend to operate at 1200 to 1800 much of the time.
The YM2610 is one of the nicer Yanmars Fredrick's puts out. That and the YM1720. The YM2610 has the PowerShift and the 4 speed selection PTO. The JD 850 uses the same engine. The JD 850 is the clone of the YM2500. Both are 4 speed geared. PowerShift gives you the 'live' PTO so you can mow forwards-shift-backwards without spinning the PTO down using the clutch with the YM2510 over the YM2500/JD850.
Parts in the USA for the JD850 JD750 JD900HC with the 3T80 are plentiful. The UK Yanmar YM257 uses the 3T80 and so does the Yanmar gensets and Marine here.
Thus, in years ahead, both the YM2500/YM2610 should have parts available. That was why I chose the YM2610 over all the rest.
/ Model Advice #68
I may be a minority on my view, but I would take a power shift anytime over a HST. Perhaps it comes from my age and being raised with gear tractors. I have found that my speed control is very inconsistent with an HST and my foot gets very tired when do jobs like bush hogging.
With a skid steer available, I would not spend the money on a FEL either. Nor would I worry with a _______scoop (dirt, pond or whatever you want to call the scoop). The scoop can serve multiple purposes, carryall, scoop and others. Often you can find used ones in decent shape on craigslist and FB marketplace, if you want to try one.
There is another recent thread where PTO speed selection and engine rpms are discussed. Some seem to think they are saving wear and tear on the motor and others do not. Personally, I am undecided on that topic. Personally, I think one of the reasons these tractors can go close or even beyond 10,000 hrs before typical major engine problems is that much of their life is spend not at “operating” RPM’s. Many of us have FEL’s on our ‘small’ tractors and there is just no need to turn 2400 rpm to do bucket work. A fast idle of about 1500 rpm’s usually gets plenty of fluid flow. The benefit to lower rpm’s and yet maintain PTO rpm’s will save fuel and depending on how much PTO work you will do, this may be worth playing around with.
/ Model Advice #69
I don't think your view is in the minority at all. But maybe that's because I agree with everything you said.... including Yanmars' powershift over the HST.
Of course that depends on the HST. The one on our big Kubota coupled with it's automatic return to idle, adjustable HST attack rate, and a fingertip lever split-shifting rear axle that gives double the ranges....well, it's a pretty nice HST. In fact the best I've ever seen or used. But like you say, my foot still gets tired if I am going any distance. The simple powershift is better for that. The powershift is pretty rugged, too. And easily repaired....which the HST is probably not.
rScotty
/ Model Advice #70
I agree with you as well.
HST has it's place, but lacks the ability when needing to tow something heavy, or to use a deep bottom plow or being stuck in the snow and ice and going up inclines. Power-Shift or Shuttle Shift or Synchronize Shift (whatever way you want to call it) for gear selection holds stronger and the engagement is solid. It's not as smooooth as an HST, but you know that you know that gear is stable and solid when the bump shift is moved.
/ Model Advice #71
I wrote that little piece because the guy has the same Yanmar. I know I was a bit taken back by it too. Coming from an old Ford 8N, the PowerShift and 4 selection speed PTO was a mind bender at first. lol :p
/ Model Advice
With the use I have planned I'd be shocked if I ever truly wore one out. I figure, keeping it under cover like I plan, rubber dry rot and hardening seals will be my two biggest issues.
My initial thought was that since tilling is my primary use, gear would be lots easier for that. Find the right speed between gear and RPM and let it go.
One other thought that I've had is that even with the skid steer, a box blade and/or land leveler would be nice for working my driveway. Figure need weight/traction for that. Is the 10 series adequate weight wise or would I be better off stepping up to a 20 series with the extra ~600lbs? The cost increase isn't insignificant but I do believe buy once cry once to meet your needs.
/ Model Advice #73
You can easily ballast up 400 pounds or so even on a non loader tractor. I have about 350 pounds of ballast on my YM2000. It makes a difference.
/ Model Advice #74
Seems to me you can add nearly unlimited weight bolted to the wheels. That doesn't stress the rest of the tractor. And a few hundred lbs bearing down permanently on the drawbar should still be within specs.
Kinda off topic: a neighbor has a MF135 for loading harvest bins two-high on his truck. The MF has massive heavy cast iron fenders. Along with weights - several hundred lbs each - filling the inner sides of the rear wheel rims. This allows lifting a ton on his front loader forks even with no load on his rear forks.
/ Model Advice #75
Remember on most of these tractors an "hour" is recorded at like 2200 RPMs (could be 2400 ) I believe it is. So running one around 1500 your only recording something like .6 hours for every actual clock hour you run it.
/ Model Advice #76
I enjoyed that write up on engine rpm and PTO speed selection. You went into lots of advanced applications of usage of these small tractors
I had stayed away from that since he had indicated he was having issues related to what did what regarding levers. My thoughts were simpler is better to get it rolling. This the 5 speed ranges and 3 forward speeds and 1 reverse in each range.
/ Model Advice #77
For the novice, to maybe clarify that a bit. 1 engine hour is 1 hour ran at PTO speed 1 at engine rpm’s to obtain 540 PTO rpm’s. Now that is probably clear as muddy water.
That said, trying to keep math a bit simple, if 540 PTO is achieved at 2400 rpm’s. 1 hour of tractor work at 2400 rpms will move your hour meter 1 hour
Idling (fast idle) at 1200 rpms for 1 hour will add 0.5 hours to your hour meter (assuming all things are equal). So work your math based on your tractors rated rpm number and the rpms you run either do non-PTO work or by using a faster PTO gear and a reduced engine rpm.
I know clear as dirty water.
/ Model Advice #78
I would initially try the box blade with no additional ballast, as adding ballast for traction is always a pain to remove. It can be done, but anyone who has done so will agree it is a pain.
As you consider ballast, think about why you want ballast! If it is for traction, you will want it as close to the rear axle as possible (even on a 4wd model). There are trade offs with any type of ballast so research each type—filled tires, wheel weights and on.
Many of us have made ballast for our 3ph due to the rear getting light using the FEL. In this mode a little weight on the 3ph may be more effective than filled tires. A big advantage to this is fairly easy removal. A big disadvantage is it is not usable if using an implement that might not be heavy enough.
Without a FEL and a heavy long rear implement, may require ballast in the front of the tractor—tractor weights.
So trying not to make this a novel, you may have a need for several types of ballast based on what you are trying to do.
/ Model Advice #79
The really funny thing about the 540 PTO speed is, most folks don't run at the full 540. More operate the attachments at or slightly below 500. My 6ft King Kutter brush mower can run at 540, but it shakes too much. At about 500, it's peeeerrrrrrrrfect.
I've talked with many folks on how fast they run the PTO for stuff. get the same answer. The only person I knew running 540 to the limit was a guy using a wood chipper.
/ Model Advice #80
True about the RPM’s we will run at. 1st is on our Yanmars, we really do not have a 540 PTO rpm but speed 1 is close. But most brands even those USA models that only have a 540 PTO speed, we will find what we each consider the ‘sweet’ speed. But for starting out with a tractor, the best advice for that newbie is to set the rpm’s at the 540 setting however that is indicated for that model.
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
Landoll 18' Tilloll (A66285)
Landoll 18'...
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A65563)
2015 Isuzu NPR-HD...
PT 4 Cylinder Power Unit (A64127)
PT 4 Cylinder...
