Model 105 bushhog
/ Model 105 bushhog #1
kennyl123
Bronze Member
Pollock, LA
Ford 2000
I have an old 105 bushhog with 5/16 bolt hole to attach the drive line but I have bought two drive lines and both have 1/2 hole . It keeps shearing bolt even after installing slip clutch. Any idea what to do!
/ Model 105 bushhog #2
so.. the hole on the gearbox smooth input shaft is 7/16 .. but the hole in the driveshaft s 1/2"
I'd either drill a 7/16 (TRUE) hole thru the driveshaft perp to the original hole.. or i'd have the input shaft 7/16 hole enlarged to 1/2"
/ Model 105 bushhog #3
Soundquy has the right answer imho, but if you want to try something make a bushing for both sides with some 1/16 in material. It might help.
/ Model 105 bushhog #4
it'll help 1 time, untill that shear bolt pops, then the head of the olt, the nut, and both the shims will fly off into outter space at pto rpm speed.. :)
/ Model 105 bushhog
Thanks for waking my brain up I had been trying to drill hole in bush hog shaft and it is much too hard. I just never thought to drill smaller hole perp. to larger hole. It worked just fine
/ Model 105 bushhog #6
yep.. the yoke is almost always softer.. etc...
and now it works on either size :)
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
PTO Driven Portable Water Pump (A64119)
PTO Driven...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
AUCTION STARTS HERE @ 9AM (A64279)
AUCTION STARTS...
