Mobile Mechanic
/ Mobile Mechanic #1
jlhtruck
jOHN DEERE 8640
Hi! I'm new to this site! I do own a new Mahindra 4540, and love it! However, I do mobile repairs on about anything diesel. Right now, I have a customer with a JD 8640 that has hydraulic problems. I'm told that I need to pull the 3 stacked pumps that are located on the rear of the front section, behind the filter base. I have no idea what I'm getting in to. I cannot afford to buy a manual for every type tractor that I work on, so can anyone help me with this? I really don't want to open a can of worms that I can't put back in the can! Anyone?
/ Mobile Mechanic #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section to see if we can find you some advice.
/ Mobile Mechanic #3
First I would post in John Deere AG Tractor section
Second describe problem and why you think these pumps need to be pulled.
Third look in JD's online parts catalog. I looked, and found these drawings.
I will say I have never seen or worked on this big of a tractor, but from what I saw on JDparts.com:
I would start with checking/cleaning or replacing all shown screens and filters before tearing out internal pumps.
Then, if problem persists (after clean/new screens/filter) dig deeper.
GOOD LUCK!
/ Mobile Mechanic #4
For the drawings in the above post, (I never know what order they will load):
Drawing 1 clutch pump screen key 17
Drawing 2 Transmission pump screen key 14
Drawing 3 Transmission filter key 10
Drawing 4 Transfer pump screen key 4
Drawing 5 Clutch and transfer pumps
/ Mobile Mechanic #5
:welcome:
Could you please move to the JOHN DEERE AG TRACTOR sub forum???
/ Mobile Mechanic #6
Pressure test things, often you have several measure points for hydraulikk pressure and that should be the starting point. But you must know the value, if you don't have books I think I would pass the job.
/ Mobile Mechanic #7
I'm leaning towards Agvg..
Being a mobile mechanic you HAVE TO KNOW what your doing/buy the manuals.. IF NOT, your no better off than the guy that called you..
What are you gonna do when you spend 4-5 hrs on it & turn & say, sorry I cant fix it.?? Charge the guy 400.-500.00 & drive off??
or tell the guy he "might/probably" needs a hydro. pump that costs 1000.00 & it doesn't fix the problem..
You wont stay in business very long like THAT..
I don't mean to sound critical but you might wanna consider passing on the job.. Just tell the guy, "Sorry, but thats alittle outa my wheel house"..
/ Mobile Mechanic #8
And how does the customer know it's the pumps? Are you taking over somebody others failed job? Can bee very time consuming to verify that all is there and are OK when you don't know what's been done.
/ Mobile Mechanic #9
Or even worse -- compound the problem.
Manuals and part diagrams are essential. Either that or get a Bronson rock.
/ Mobile Mechanic #10
It's why more and more, I don't want to get out of bed in the morning. It seems that nothing out there is easy anymore and less and less friendly to the little guy. Like, everything turns into a can of worms! Just figuring out how to take something apart can be a major hurdle never mind repairing it.
/ Mobile Mechanic #11
Friendly? Just some advice, if you are to repair complex machinery you must have knowledge, tools and data in form of information on how and what.
/ Mobile Mechanic #12
I think JD offered the 8640 from 78-79 thru 82-83. If it is a 82-83 model it is 35-36 years old. The owner has probably had it looked at a JD Dealer and was floored by the repair estimate. So he started looking for a independent to take on the job. If I was Mobile Mechanic I would pass on attempting repairs. That is one huge tractor.
Most JD Dealers will not discount parts to a independent. So Mobile Mechanic would have some expensive parts to eat if his guess as to what the problem is, is wrong and he has to move on to more expensive parts.
/ Mobile Mechanic #13
To check for a private message go to the top of the page, click on ALERTS. Drop down to inbox.
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
Sakai SW354 (A60462)
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
