Mobil Radios
/ Mobil Radios #1
TonyC
Platinum Member
Monroe, Va
Kubota 1997 L3600DT 4WD with FEL
Anyone have any experience with those newer Motorola communications radios on the FRS frequency? Some models are getting pretty inexpensive and I was womdering if anyone has any experience with their performance.
/ Mobil Radios #2
I don't know about the Motorola models, but I do use FRS radios. I have a NADY. It's specifically designed for use on a motorcycle. It has a driver/passenger intercom system which enables the passenger to talk not only to the driver but also to others. Once off the bike, they behave like normal FRS radios. Indispensible for fishing and hunting trips. Also good at large events like car and bike shows (tractor shows). Range is about a mile, depending on terrain.
/ Mobil Radios #3
I got a set for Christmas. Based on the traffic it seems like LOTS of people (kids) got them too.
Haven't really had the opprotunity to really try them out though.
/ Mobil Radios
Well at least where I live, there will be no other traffic. Let us know how you do with them. I don't need for them to go a very long distance but there will be some steep hills in the way.
/ Mobil Radios #5
Seems to me that Harv or someone had an in depth discussion on these including model numbers etc. I believe he was going from a safety standpoint....ie out alone on the tractor. If you search for that thread it would likely help a lot!!!
Kevin
/ Mobil Radios #6
I shouldn't be so lazy....here's the tread <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=safety&Number=58394&page=&view=&sb=&o=&vc=1>Harv's thread</A>
/w3tcompact/icons/blush.gif
Kevin
/ Mobil Radios #7
Tony: I have a pair of the Motorola FRS radios (Model 80, I think). My experience with them is that they are pretty much line-of-site. The max range I've gotten out of them is about a mile and that was over VERY mildly rolling terrain. A real hill of any kind completely cut out the signal.
I think the basic concept behind the FRS, unlicensed operator radio frequencies is that they are so low power that even the most inconsiderate/un knowledgeable operator can disrupt the operation only a very limited number of other operators because of the distance limitations.
/ Mobil Radios #8
Yep, that's the thread, Kevin. Thanks for finding it.
Tony -
I've been using the Motorola TalkAbout 250's ($45 after rebate) for about 6 months now, and I am still impressed. Anything close to line-of-sight and the range is definitely more than half a mile (haven't tested it farther than that). With hills in the way it drops off quickly, but even then I get a quarter mile. The only time I lose complete contact is when I drop down into a serious ravine. The most impressive thing about these units is the clarity. If you get a signal at all, it's like somebody's standing right next to you. Good battery life, too.
In that other thread I mention that I also bought a couple of Audiovox FR1420's for the kids. The spec's were similar to the Motorolas, but they were available at $60 for the pair. They work on the same channels as the others, but I gotta tell you they were a waste of money.
Their range is poor and the clarity is worse. /w3tcompact/icons/tongue.gif The battery life also leaves much to be desired.
Stick with Motorola and you'll do just fine.
/ Mobil Radios #9
We have been using FR50's for the last couple years and on level ground you can reach up to 2 miles on clear days. If it is snowing you will only be able to talk for about 1 mile. We use them when we go out to hunt so that we can keep track of everybody and do use them on some hilly ground and have not had any problems with them at all. The FR 50's come in a two pack for around $35 at Wal-Mart and are worth it. We have 4 of them and one got run over by an Explorer and it still works you just can't see the LCD screen. There are 14 channels on them and if you do have traffic on one channel you just switch channels as it is doubtful there are 14 different groups within 2 miles of you using these radios.
/ Mobil Radios #10
I have had a set of Motorola FR60 Talkabouts for nearly 3 years now. Used during travel across country in two vehicles and they were a tripsaver. As mentioned by others, distance is basically line of sight. I've found many practical uses:
Boat to cabin, upstairs & downstairs in house while fixing something with a need to talk to someone and many times when away from the house on the property. Very good value for the cost today.
/ Mobil Radios #11
I have a couple of the Kenwood FRS radios. They work great. Have gotten a good 2 miles of range out of them here in the flatlands of Kansas. I see a few companies are coming out with GMRS radios. Same frequencies but have more power. They claim 5 mile range but these are all line of sight radios so it may or may not be of value. Price is more in the $150 range I think.
/ Mobil Radios #12
We have 4 Motorola 6220's, about $35 each with coupoun. Use them at events, fairs, etc when the family goes in all different directions. They use 3 AA batteries, not sure of life, usually replace them each day of use. A radio with dead battery is not worth much. Range appears about 2 miles, but we have never really tried to determine max range, and they do pretty good in and around metal buildings. We have 2 Cobra FRS80's here at work, used to communicate between cafeteria and satelite cafeteria with much steel inbetween, work well, although the ni-cad batteries don't work well. The radio's have a low battery cutout that doesn't allow for setting battery type, the lower voltage of ni-cad's cause short use time. The Motorola's I have are settable as to battery type to prevent this problem.
/ Mobil Radios #13
I have a number of mobile radio's in my truck including FRS. Depending on the range and terrain, FRS may work for you.While the ads says FRS is good upto 2 miles, most are not usable past 1/4 mile. NOTE!!! There are some radio's that claim 5 miles, These are NOT FRS (even if the box says they will talk to FRS radio) and are GMRS radio and require a license ($85).
My mobile is a bit crowded, but I do have one more radio to squeeze in .
http://www.k2bj.com/images/Photos/MOTM/sanders_3.jpg
FRS radios can be had for as low as $15 and as much as $200 depending on the features.
Note FRS has only 14 channels. There is no such thing as a subchannel even if your manuals says it has it.
The so called sub channels are simply sub tones or digital squelch. They provide no privacy (again no mater what the manual says). they simply keep your radio from hearing other converstation that dont match your tone.
If you are ok with the short range then FRS may be for you.
/ Mobil Radios
First a double thank you to Kevin for digging out the thread.
And thank you Harv for all of the info. I am thinking about getting either the T-5100's or the T-5200's. They run $35 and $33 each respectively. I think the only difference is the T5200 has the interference eliminator codes. I don't know how useful that is but it sounds good!
/ Mobil Radios #15
Do any of these FRS type radios have a jack for remote headphones? I have an application where two motorcycle riders, who are about 100 yards apart, need to comunicate easily. But helmets are worn so headphones of some variety is necessary.
Peter
/ Mobil Radios #16
I was looking at a Cabela's catalogue the other night noticed that the Motorola units have a whole collection of remote mike accessories and I know mine has jacks.
/ Mobil Radios #17
This is the primary function of the Nady MRC-11. I believe most FRS radios have a headset jack, but on a bike you also a need a remote push-to-talk (PTT) button. The Nady comes with one. Added bonus - you can plug in an external audio source (radio, MP3 player) to the Nady and it will play through the headset. The external audio is cut when you press the PTT button. More info at <A target="_blank" HREF=http://www.nadywireless.com/mrc11.html>http://www.nadywireless.com/mrc11.html</A>
One thing though, I haven't been too successful at getting the VOX to work properly at speeds.
/ Mobil Radios #18
<font color=blue>any of these FRS type radios have a jack for remote headphones? </font color=blue>
Yep, my Motorola TalkAbout 250's have both a microphone and headphone jack. According to the manual, they have a VOX (Voice Activated Transmission) mode, too, but I haven't tried it yet.
/ Mobil Radios #19
Thanks for the info. Looks like I have created another research project.
As if designing a barn isn't enough!
Peter
/ Mobil Radios #20
Russ,
GMRS and FRS are different, even though there are 7 overlapping channels.. GMRS is a licensed service, even when using the shared channels. FRS is an unlicensed service. Note, unlicensed does not mean no rules. There are FCC regulations around FRS radios.
GMRS has been around for 20 years, FRS only a few. GMRS can go upto 50watts of power depending on freq, GMRS can use repeaters for large coverage. GMRS requires a license ($75 for 5 years). GMRS also allows removable antennas to improve range. FRS antennas are fixed.
Range from a GMRS 5watt vs a FRS 1/2watt radio is often a fact of the quality of the radio. While 5watts will travel farther than 1/2 watts. The GMRS radio are often better constructed radios. Your low end FRS radio selling for $20 or even the $50 FRS radio is not going to have the quality compoents or filters a $150 and up radio would.
Mini rock grapples (A61567)
Mini rock grapples...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2012 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2CJ453403 (A61165)
2012 International...
2017 ADDCO ROAD SIGN DH100-ALS (A60736)
2017 ADDCO ROAD...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
00BBL WHEELED FRAC TANK (A60736)
00BBL WHEELED FRAC...
