MMO in Gas Tank
   / MMO in Gas Tank #1
8N_John
Kearney, Missouri
1952 Ford 8N
Is it OK to put Marvel Mystery Oil in the gas tank as well as the oil? I have a 52 8n. Just bought it. It seems to sputter periodically and I thought some MMO couldn't hurt???
   / MMO in Gas Tank #2
I think I would check on the ignition system first, plugs included as well as coil, points and condenser, cap too. Then look at the fuel with a look at the sediment bowl to check for water, and know you have good, and clean, gas.
I've no idea why MMO would be a cure for anything that makes the engine sputter, but then I don't know everything. /forums/images/graemlins/wink.gif
   / MMO in Gas Tank #3
Only possibility may be a sticky valve.
While adding it to the gas may help.. We've had better luck actually pulling the valve covers and dousing the valve stem with MMO and manually actuating them... Usually solves plain 'sticky' valves that don't have an otherwise 'hard' mechanical defect.
I'd also look to points ( and all other ignition components.. including key switch, and ballast resistor, if equipped) and fuel ( and the valves) for an occasional sputter.
Soundguy
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
