MMM or Rear Finish
   / MMM or Rear Finish #21
Owning both MMM and rear finish mower mounted up to two different tractors - I have specific areas with different terrains, etc. that I'm mowing where each mower shines. One bonus that wasn't mentioned yet in this thread - your tractor will stay much cleaner with the rear finish mower. All that dust , dirt, leaves, grass clippings, etc. are well behind you.
PowerMax
Excellent advise , thanks. I do not have the option for a MMM my tractor is a Kubota L3000, just wanted to get the ins and outs of rear finish mowers- do you have service them often?
   / MMM or Rear Finish #23
design tip: plant trees VERY far apart!
another tip: NO SQUARE CORNERS! [think gently flowing LARGE radiuses!]
these tips also work well with belly mowers too...
   / MMM or Rear Finish #24
Newland--
I have a TC33D with a belly mower. I leave it on most of the time in the summer, and can get it on and off in 10-15 minutes BUT that is using the FEL to lift up the front end. I think it would be a good bit more complicated without an FEL, as the clearances are pretty tight. I like the belly mower precisely because it is like a garden tractor; easy to line up and keep an eye on around trees, etc., and a lot easier to keep track of around gardens, rocks, etc. Also, I used to have a Yanmar with a three-point finish mower and had a little more trouble with scalping than with the belly mower. Tail-draggers take some getting used to because when you crest a rise the mower comes off the ground, etc. While neither is a perfect solution, I am a tad bit partial to the belly mower--except when I want to have it off but don't want to deal with it. BTW, it is pretty tough; truth be told I drag it through gravel and dirt, leave it on while bush-hogging, etc. The best thing, of course, would be to take a try at each before you make your decision; but if you can't do that, just remember there are advantages to each.
Thanks for all the comments they are very helpfull. I just came back from a bush hog dealler and really liked the RDTH72. The rear discharge sounds like it may simplify things, no more clippings in places I don't want them and no circleing around to make sure the side discharge is pointed the right way. Has anyone had a rear discharge and not liked it?
Thanks again,
Newland
   / MMM or Rear Finish #26
Newland,
I have a FTH60 Bush Hog side discharge. I am sure the rear discharge is nice.
One thing I like about my side discharge is that it acts like a giant leaf blower. Using forward and reverse on the tractor I can "blow" the leaves into the woods along the fence line.
Not a huge deal but it is nice.
   / MMM or Rear Finish #27
Lets see your field mowing not a finished lawn. What about Just hitting the right or left brake, steering hard over. It should square a nice corner, everywhere but in the corners of the field.
   / MMM or Rear Finish #28
My only experience prior to my recent purchase of a L3010 was with an 8N. 1952 model. I had a single wheel KK brush hog and had a heck of a time making the corners. I think i also had to much sway in the 3PH hookup, and I always had lots of cleanup to do after mowing.
I decided to go with the Rear Finish mower on my 3010 and what a difference!!! It does a better job at cutting the corners than my 48" MMM on my simplicty lawn tractor. And, when i do leave a patch; with HST to back up and get it is so simple, a very quick and easy process. I'm tickled pink with the operation of the new setup. Consider me a Rear Finish Mower convert.
Thanks for your reply Kodiak!
Moon
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
10 ft Wrought Iron Fence (A56859)
10 ft Wrought Iron...
White 5100 Planter (A59814)
White 5100 Planter...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
