MMM ground clearance.
/ MMM ground clearance. #1
Ronster
CT
John Deere 2520, John Deere X739, Kubota U27-4, Kubota RTV 500
I was at a local dealer this morning trying to decide between the B7610 and the B7800. I noticed that the FEL brackets appear to be closer to the ground on the B7610 as compared to FEL brackets on the B7800. Neither machine had a MMM on it, but it looks like the MMM on the B7800 should raise at least 3" higher than the B7610 MMM. Anyone have a pic of either tractor w/ a MMM on it?
Is there a B7800 and/or a B7610 MMM owner that can measure the ground clearnce with the mower deck raised?
My local dealer doesn't have a MMM on either machine and can't really give me an answer.Thanks. /forums/images/graemlins/cool.gif
/ MMM ground clearance. #3
Ronster -
I don't have my MMM mounted at the moment - so I can't give you an exact figure.
However - I have some pics on my website (showing MMM removal) - the first of which shows the MMM fully down. I think that the MMM can be raised @ 5-6" from the down position - so I'm going to estimate something like 7 - 8" of clearance under the MMM deck when fully raised.
MMM deck pics (removal sequence)
As my pics show - I can take my MMM on / off in @ 5 minutes - so I don't really consider clearance an issue if I'm not mowing - as I leave the MMM off. I also take the FEL off for mowing - another 5 minutes or so - so in total it takes me @ 10 minutes to *convert* from a "FEL only* to *MMM only* configuration and back.
Hope that helps.
Dan
DanR67, thanks for the info. That's a fine looking machine. As soon as I find a buyer for my 7234 Cub, I'd like to get a Kubota like yours. I'm still torn between the B7610 and the B7800. If you could do it all over again, would you still buy the B7610 again or a different model?
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
PALLET OF PLASTIC BREAD BASKET (A64281)
PALLET OF PLASTIC...
CATERPILLAR 573D FELLER BUNCHER (A64276)
CATERPILLAR 573D...
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
JMR TREE BOOM (A61572)
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
