MMM Cutting Height Adjustment
/ MMM Cutting Height Adjustment #11
RaydaKub.............try that link that EricK posted in #3. There is a picture of the fix with a washer sitting on top of the cam. The part that you call the "finger" was worn as well on mine. But the washer fix seemed to cure the problem. For sure if you took that all apart to weld, that would be a big job in my mind. Yet, I haven't put my MMM to work that much since the "fix". We'll be soon to find out however.
Cheers,
Mike
Interesting. Why does that work? Maybe it doesn't rock side to side as much? It's certainly worth trying before I dismantle the tractor.
My mower has been abused a fair amount prior to my purchase of it. The right front scalp wheel has been hit hard enough to bend the front mower flange in toward the blade. Also the angle iron where the limit control sits was broken right off the frame. I had that welded back on the first summer I owned it, but it has gotten worse again. I put a hydraulic jack in the mower deck to stretch it out again, but was only about 50% successful.
Yeah, that right front wheel/mount takes a beating on mine as well. In fact, I've welded it three times front the hits. Need to stay further away from obstacles no doubt. My 2012 B2620 has about 550 hrs on it, most of it mowing my place. But I do help out neighbors whose places get out of control. I think that's where most of the damage comes from (rocks/sticks/junk/stumps etc.). A Brush Hog would be a better tool for those places.
Well.....................The "fix" did not work. It holds better now but still drops to a lower setting as one mows along....especially when hitting a bump/hole. The set knob is so tight that I can just barely adjust it. I have to agree with the previous poster, JWR, that there is something else at work here since most of the B/BX MMM owners don't mention this problem. Arg-g-g-.
2020 DRAGON 150BBL ALUMINUM (A60736)
2020 DRAGON 150BBL...
Spreader Attachment (A56859)
Spreader...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
