MMM cleanup
/ MMM cleanup #1
abheye
Western NY
1957 Case 311, Cub cadet 800, 1981Snapper LT11,2002 Kubota B7500HSD
I found this 110 volt winch in Harbor Freight tools for under $100, and find it very helpful. It lifts up to 440lbs.
/ MMM cleanup #3
If it's really a winch, you might want to use caution since it seems you are using it as a hoist. I've seen many winches that will state that they should not be used for lifting purposes.
Be carefull !
/ MMM cleanup #4
<font color=blue>I've seen many winches that will state that they should not be used for lifting purposes.
</font color=blue>
Here's a <A target="_blank" HREF=http://www.superwinch.com/support/learning/hoisting.html>link</A> to an explanation of this at the Superwinch site. The pertinent sentence is...
Superwinch products are neither hoists nor elevators and should not be interpreted as such.
/ MMM cleanup
It is a hoist, sorry. Chicago, model #40765. wwwHarborFreight.com, I was skeptical till I put it to use.
/ MMM cleanup
manual
/ MMM cleanup #7
Hi,
I see they are on back order, but also on sale for 79.99 at northern tool's web site...
I'm tempted to order one!
Bill in Pgh, PA
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
