Mowing MMM belt life?
/ MMM belt life? #21
I bought my tractor used with close to 400 hours and now have 480 hours, most of which is from mowing and my belt is still in great shape.
/ MMM belt life? #24
For those of you that use your Kubota's with a MMM to mow, how long would you expect the belt on the deck to last? I got about 60 hrs. out of mine when it went on me. I believe my deck is an RC60-25 mounted under an L2250. I was hoping to get more life out of it. Price of a new belt from Kubota was about $98.00. I ordered one from CBS equipment for about $51.00.
Abe.
Just shy of 800 hours and 12 years so far.......
/ MMM belt life? #25
AbeK,
Kubota uses a very heavy blade. The rotating mass (inertia) of the blade will carry it through the grass/weeds if the RPM is high enough and the blades are sharp. I mow at wide open throttle. These little diesels are made to run WOT and you won't hurt it a bit. You can cut the RPM back a little if going slow or in short or thin grass.
/ MMM belt life? #26
I have a BX2350 with about 360 hours on it, maybe 200 hours is mowing. I am on my 3rd belt. The first two only lasted maybe 50 hours each, this last one seems like its going to last longer. I have also noticed the belt will vibrate at less than full throttle, but I always mow with it wide open. I'm pretty hard on the mower and occasionally get a stick or something caught in there.
/ MMM belt life?
I have had a bx22 and now a 24...Never releave tention in winters and new had replaced a belt yet.
Was the mower set-up correctly?
Hi sw03; When you ask "Was the mower set-up correctly?" What is there to set up besides making sure the belt is routed correctly?
Abe.
/ MMM belt life? #28
I have a 14 year old B2400 with about 1000 hours with the original belt. Still going strong. Most of the 1000 hours was mowing, at least 75 percent.
/ MMM belt life? #29
7 mowing seasons and over 600 hrs on original OEM belt and my BX23 w/60" MMM is showing no apparant issues. Mowing season runs Mar - Nov....
I mow at just a hair under WOT, run gatorblades and finish mow 2 acres weekly and another 2 acres bi-weekly.
Dave
/ MMM belt life? #30
My 05 BX23 with over 1200 hours with a 60 mmm and mow 5 acres with original blades and belt and run WOT. I have chopped up finger size brush and have stopped the blades hitting and wedging stones or branches in areas that I have added to my finish cut area once done with the brush hog.
/ MMM belt life? #31
1998 B2400 with 1500hrs and I would estimate 900 of those on deck. Still have original belt. I do take tension off of the belt when I store deck for winter, but other than that, I just use/abuse it!
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
2019 CATERPILLAR 320GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2019 Deere 550K (A53317)
2019 Deere 550K...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
