Ml108h loader question
   / Ml108h loader question #1
Mattyboy936
Mahindra 3510
Hi there, quick question regarding my Mahindra.. it has a ml108H loader on it. Seems smooth going up and dumping but extremely sensitive and quick jerking when lowering..
Using some clamp on forks the past two days to move some 10ft logs around my property and raising it is smooth… but tilt down or drop is dangerously jerky.. even when you try to baby it.
Any adjustments on the spool valve or is that just the way they are?
   / Ml108h loader question #2
There are no adjustments on the valve. Some valves have significantly better metering characteristics than others which is what allows the precise movements.
A band aide is to put an adjustable flow control in the lower and tilt line on the loader to limit how fast it will move in lower and tilt.
Real fix is finding a FEL valve with great metering in the flow range of your tractor.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2018 GENERAC MAGNUM PORTABLE S/A LIGHT TOWER (A51243)
2018 GENERAC...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
