Mixing used oil for dumping
   / Mixing used oil for dumping #1
40_acre_mule
South Mississippi
Kubota L4701
Didn't find this through a search...
I know you shouldn't mix things like anti-freeze or acetone in your used oil when taking it in for recycling.
But, what about mixing in tranny fluid, old diesel fuel, or hydraulic fluid? How about old gasoline?
As long as they are all dino and not synthetic, aren't they all just different degrees of the same thing?
High school chemistry was a long time ago for me, but I suspect some of y'all probably have a lot of knowledge in this subject.
Thanks for your answers.
   / Mixing used oil for dumping #2
I don't know about diesel or gasoline, but the place where I dispose of my used oil accepts motor oil, transmission fluid, and hydraulic fluid all in the same bin.
Lawrence
   / Mixing used oil for dumping #3
Diesel should be OK since it is an oil based.. Gasoline would be NO-NO though..
   / Mixing used oil for dumping #4
Generally they will accept anything not chlorinated. Gasoline is fine, most petroleum products are fine. Antifreeze is not. Paint thinner is not. We mix transmission fluid, power steering fluid, engine oil, gasoline, kerosene, and diesel fuel. We keep all oil contaminated with coolant seperate and our waste oil hauler usually takes it away in seperate containers. He runs a chlorine test on our container before he will accept our oil EVERY time. We had a customer bring in oil mixed with paint 1 time and we had to pay nearly $500 to get it hauled. We now keep our container locked.
   / Mixing used oil for dumping #5
Brake fluid is a BIG NO-NO in used oil. I wonder if that is where the chlorine comes from? /forums/images/graemlins/confused.gif
   / Mixing used oil for dumping #6
i have safely dumped oil, tranny fluid, hydraulic fluid (tractor), diesel, (and very very small amounts and diluted at that )gas.
Antifreeze, as others have said, are a NO NO.
my next dump of hydraulic fluid is going to my chainsaws....
   / Mixing used oil for dumping #7
Whats is the trouble with the brake fluid?
   / Mixing used oil for dumping #8
You said "my next dump of hydraulic fluid is going to my chainsaws.... " Could you explain that please? What can tranny fluid be used for on a CS?
Thanks,
David
   / Mixing used oil for dumping #9
</font><font color="blue" class="small">( What can tranny fluid be used for on a CS?
Thanks,
David )</font>
In place of bar oil- my guess
   / Mixing used oil for dumping #10
Exactly, bar oil. And, not tranny, hydraulic...
STORAGE FEES (A52141)
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
