Mixing hydraulic oils
   / Mixing hydraulic oils #1
Stomper
Saskatchewan, Canada
2017 Kubota L2501
I just finished the hydraulics on my log splitter and have 3 gallons of AW68 oil I was going to use but I need more than 3 gallons. The place I get my oil from doesn’t have anymore of the AW68 but they have AW46 and AW32 in the same brand. Can I mix them together. Will it just change the viscosity of the oil.
   / Mixing hydraulic oils #2
Yes you can mix oils from same manufacture and it will change the viscosity some.
   / Mixing hydraulic oils #4
No issues mixing viscosities....but since you "have" the 68 an are gonna mix 46 with it...it will make the oil slightly thinner.
Not an issue if everything is in tip top shape. But if it is already weeping a little oil at the gland seal like I see so many cylinders do....this may simply make it weep a little more
   / Mixing hydraulic oils #5
Isn't AW68 awful thick for Saskatchewan?
AEREATOR (A58214)
AEREATOR (A58214)
1629 (A57192)
1629 (A57192)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
