Mixing hydraulic oils
/ Mixing hydraulic oils #1
Stomper
Gold Member
Saskatchewan, Canada
2017 Kubota L2501
I just finished the hydraulics on my log splitter and have 3 gallons of AW68 oil I was going to use but I need more than 3 gallons. The place I get my oil from doesn’t have anymore of the AW68 but they have AW46 and AW32 in the same brand. Can I mix them together. Will it just change the viscosity of the oil.
/ Mixing hydraulic oils #2
Yes you can mix oils from same manufacture and it will change the viscosity some.
/ Mixing hydraulic oils #4
No issues mixing viscosities....but since you "have" the 68 an are gonna mix 46 with it...it will make the oil slightly thinner.
Not an issue if everything is in tip top shape. But if it is already weeping a little oil at the gland seal like I see so many cylinders do....this may simply make it weep a little more
/ Mixing hydraulic oils #5
Isn't AW68 awful thick for Saskatchewan?
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
Wooden rocking chair (A61569)
Wooden rocking...
FUEL CELL (A58214)
FUEL CELL (A58214)
