Mixing hydraulic fluid when using used attachments
/ Mixing hydraulic fluid when using used attachments #1
hamdog
Bronze Member
Northern
Is there an issue with potentially mixing/contaminating hydraulic fluid when buying used implements or borrowing used implements?
/ Mixing hydraulic fluid when using used attachments #2
I use a pull type fertilize spreader from the company I buy fertilize from 3 or 4 times a year, but the cylinder is always retracted when I get it, I'm sure there is a little mixing from operating the cylinder but I have never had a problem or noticed my hydraulic fluid being any different.
/ Mixing hydraulic fluid when using used attachments #3
I don't think you'll have much issue. There's not really that much fluid in a cylinder when it's retracted, unless it's a big one... Chances of someone having a tractor with such rancid fluid that it wrecks something in your tractor at a 30 or 30:1 mix ratio is pretty unlikely. If you notice the fluid change color drastically after using a borrowed attachment, do a fluid change a bit early.
And most oils used in hydraulic systems are compatible. Even engine oil or gear oil is going to be fine mixed with hydraulic oil in small quantities.
1stDeuce - that's what I was thinking, but didn't know if the same hydraulic fluid serving implements also serves the HST transmission. People do it all the time. I was just looking at used implements and borrowing my father in laws (dumpcart, harrows w/hydraulic lift). Thanks again for the quick reply
/ Mixing hydraulic fluid when using used attachments #5
HST machines & most modern tractors have a common sump hydraulic system. All the fluid ends up in the transmission. Saves having to stock, check & change multiple fluids.
I haven't borrowed or rented any impliments yet, but the contamination concern has been in the back of my mind as well.
Plan B is to pull off the QDs or hoses & drain the hoses & cylinders into a bucket. I did that on the cylinder for my used 3pt trencher. Of course I needed to replace the QDs to fit my machine as well. May not have bothered if the QDs had fit, but it was good piece of mind.
/ Mixing hydraulic fluid when using used attachments #6
Flush some from your machine through when you get started. Connect only one side and put a fitting on the other, operate the valve appropriately. Done
2017 Chevrolet Sonic Hatchback (A61574)
2017 Chevrolet...
Caterpillar 970F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 970F...
Caterpillar Vibratory Compactor Parts and Service Manuals (A63117)
Caterpillar...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
