Mixing fluids?
/ Mixing fluids? #1
fruitcakesa
CavendishVT
M6040 JD 450C
The prior owner of the M4 071 used Napa premium hydro fluid for all the hydraulic services during the 1800 hrs he owned it with no apparent problems. I have always used Kubota Sudt for service on my other tractors.
Can Sudt be mixed safely with other “compatible” fluids?
/ Mixing fluids? #2
Nowadays the “industry standard” is equivalent to John Deere J20C. It usually will carry the name “Universal/Premium Tractor Hydraulic/Transmission Fluid.” Any oil that is spec’d out to that spec should mix perfectly fine. I am not familiar with Kubota UDT specifically, but I know that brand does not matter near as much as api specs and viscosity of the fluid. If the specs are the same, they should mix without issue.
/ Mixing fluids? #4
If the tractor has an HST transmission UDT2 is recommended if you really want to play it safe. If it's a standard transmission a mix should work fine.
in addition, detachable hyd attachments carry residual hyd oil in the lines (and possible condensation) that should be kept in mind given OP's question, ie possible contamination outside the hyd tractor housing.
/ Mixing fluids?
Gear drive machine.
Would the same be true for front axle line? 80/90 vs Sudt? Are they compatible?
/ Mixing fluids? #6
Below is some data from the manufactures themselves showing compatibility.
Napa premium tractor hydraulic fluid is J20C compatible.
Kubota Super UDT is J20C compatible.
J20C (HyGuard) is compatible with Kubota UDT.
Simple answer is that the Napa Premium Tractor Hydraulic fluid is compatible with the Kubota Super UDT per the Manufacture.
/ Mixing fluids? #7
The API dosnt measure hydraulic oil and i have never seen there star burst on a jug.
Either way mixing of the simular hydraulic oil should be fine.
/ Mixing fluids? #8
Kubota specs gear oil or hydraulic oil for the front axle, at least on the L series machines. From the factory they use SUDT hydraulic oil. Mostly so they only have to spec & cary a single fluid from the factory.
/ Mixing fluids? #10
I emptied my Mahindra and put in SUDT2, and been running it for 5 years now with no issue. Less whine and always runs well. The kubota stuff is top knotch and it won't hurt swapping them. I would personally drain all the previous stuff and do a total swap rather than little by little.
/ Mixing fluids?
Since the tractor seems to be running well and the PO did a full fluid and filter change only 200 hours ago, I’m going to run it as is for now.
