Mixing different ply tires
/ Mixing different ply tires #1
paul dyar
Bronze Member
Anderson S.C.
TC33DA
Would there be a problem mixing different ply tires on a trailer. The tires will be the same size.
Thanks,Paul
/ Mixing different ply tires #2
Should not be a problem if trailer is empty, however you have to remember that the B,C,and D's have a much lower weight carrying capacity then lets say E Range Tires. Also, most regular C's& D's will only give you about 50 lbs. max air pressure while the E's will take 80 lbs. This is a factor on how much weight your trailer can carry.
DevilDog
/ Mixing different ply tires #3
As DD said there will be a variance in load capacity and air pressure. Most C ply are rated at 50 psi, D ply are rated at 65 psi, and E at 80 psi.
If possible get all the same ply rating and if you do miss match go with the sum of the lower value for you payload capacity.
Chris
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A61568)
2015 Hyundai...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
3pt 7' Chisel Plow (A60463)
3pt 7' Chisel Plow...
Rhino HPHD 3pt Auger (A60462)
Rhino HPHD 3pt...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
