Mitsubishi mt372d transmission problems!!!
/ Mitsubishi mt372d transmission problems!!! #1
mtestagolf
leominster,ma
new holland tc33d
Bought this mt372d years ago from a landscaper with only 70 hours on it. I use it to push a golf ball picker on a driving range. Its perfect in the spring because of the wet field conditions and great on fuel. Picking the other day it popped out of 3rd gear and happened again yesterday, doesnt pop out of other gears. I pulled the shift stick cover off, the fork seemed fine and the gears seemed fine other than 3rd gear seemed a little worn compared to 1st and 2nd. When I lined up 3rd gear didnt seem to engage fully. The main gear where the 3rd gear goes to has some play sliding back and forth one side is a snap ring but can tell whats on the other side of the main gear. My question is anyone have a parts list(pictures) diagram of the transmission, and can parts still be gotten for the transmission, thanks Mark
/ Mitsubishi mt372d transmission problems!!! #2
See if this helps: Satoh Parts
Not an MT372d but I believe the transmissions are the same as a Satoh 370 and 372 but I'm not 100% sure. Mitsubishi bought out Satoh and transitioned them to the Mitsubishi name. Call the number at Satohparts.com and they can help with used parts usually. New parts are probably not being produced anymore but you might be able to get NOS parts.
Thank you, it does look the same by any chance do you have the part numbers? Gear #9 looks worn, havent broken down yet but can see that gear I think there may be a snap ring missing or a bearing gone, also do you have a picture of the sifter components one of the forks are a little worn on one side, I have gotten a clutch from Satoh before thanks again, Mark
/ Mitsubishi mt372d transmission problems!!! #4
I do not have a parts list. If you call Valley Power they should be able to help you. Bill is the name of the gentleman who owns the place (the to best of my knowledge) and he is a very good resource but I don't know how much longer he will be doing what he does.
Yes it is Bill, I started ripping apart yesterday, didnt think he would be there being Easter Weekend will call him tomorrow, thanks
Thanks, CausticUrbanCoast.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
Towable T/A Flammable Liquid Transport Tank (A59228)
Towable T/A...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
1770 (A58375)
1770 (A58375)
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
