Mitsubishi MT372 starting problems
/ Mitsubishi MT372 starting problems #11
It sounds like you have air in the lines, crack an injector line and see if your getting fuel and do this to each of em. Also if it has sat for awhile check the air cleaner for debris or something that has tried to make a new home.
/ Mitsubishi MT372 starting problems #12
If not cranking fast enough it can be a PITA to get started.
/ Mitsubishi MT372 starting problems #13
I feel your fustrations on this board. I am a diesel machanic.
I've worked on your issues with many customers. Feel free to give
me a call at 903 603 9171.
/ Mitsubishi MT372 starting problems #14
Have you checked compression? It should have 425-450 pounds of compression.If it is under 400 they are hard to start.If compression is down the rings are bad or you have a cracked piston. We have the parts to fix it.
Small Import Tractor Supply
503-628-6319
/ Mitsubishi MT372 starting problems #15
i have a mt372d but its doing the same thing that your saying as well ive drained the fuel added new bleed the lines cleaned the injectors warmed the glow plugs and everything and still wont start
/ Mitsubishi MT372 starting problems #16
maybe if you put in a block heater on the tractor and plug it in until the engine gets warm to the touch then try starting it .you may be rewarded with a start.i was able to start my d1800 in the snow after it was warmed up.the glow plugs dont cut it in the winter.
2001 John Deere 6210 (A60462)
2001 John Deere...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
New/Unused Quick Attach Auger with Three Bits (A61166)
New/Unused Quick...
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
