Mitsubishi L3E IP Governor Won't Idle Properly
   / Mitsubishi L3E IP Governor Won't Idle Properly #1
777funk
Yanmar/336D
Any tips would be appreciated! Here's the problem:
-Must hold the rack half open for the engine to start.
-Engine runs great at wide open, but it's hard to turn the throttle down without killing. The governor hunts and often kills if I turn the lever down too quickly.
All was well before an engine rebuild and IP reseal. I lost the original tie rod that links the governor to the IP rack and ordered another used bar (from an L3E) on ebay. Not sure if they're all the same or not. Is there a good way to test that the throttle and governor are working correctly?
Turned out the tie rod to the pump was bent and biding the rack.
2007 VOLVO VNL DAY CAB (A52577)
2007 VOLVO VNL DAY...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2018 INTERNATIONAL LT SLEEPER (A52576)
2018 INTERNATIONAL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
