Mitsubishi KE75 engine
/ Mitsubishi KE75 engine #1
Murksmacher
Puigpunyent, Mallorca
Iseki TX1500F
Hi folks, my name is Carlos, Iエm from Mallorca.
I am interested to see some pictures showing views of thermostat hausing and water pump (right side) of the Mitsubishi KE75 engine.
As far as I know the Iseki TX1500F uses such engine but it could also fit other minitractors.
I also would like to get a workshop manual or any manual on such engine.
Thank you all. Regards,
Carlos
/ Mitsubishi KE75 engine #2
:welcome: You should be able to find links to manuals on here using search. Not all KE series engines came with a thermostat housing. In the US it appears the Bolens tractors came with thermostat housings while the fully branded Isekis did not for the KE engines although this may not necessarily be true across the board. The Satoh tractors also seemed to generally have thermostats on KE engines, but again I haven't been around a lot of them. Just something to keep in mind.
Thank you for your answer.
I am shooting in the dark because I have never seen a complete KE engine with thermostat housing, water pump and all the rest of it.
My engine was raw water cooled (it is fitted in my small sailing boat) and yes, I am a profane in this forum. Sorry for the intromission.
Being myself an engineer I decide to refit the engine with the original cooling system with the only difference compared to a tractor laying on the heat exchanger.
Please I am seeking any picture, or part breakdown drawing, showing (if any) interconnecting pipework somehow joining thermostat housing to a secondary hole on the water pump inlet port pipe.
Such hole comes from factory blanked by a threaded setscrew plug.
Any ideas are wellcome.
Many thanks,
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
