Mitsubishi KE130 No Fuel through Injection Pump
   / Mitsubishi KE130 No Fuel through Injection Pump #1
nasfell
Mitsubishi D2000FD
I'm hoping someone has had the same problem.....
I've had the injection pump evaluated and there is no issue with the pump itself. Also I have positive fuel flow from the tank/filter to the injection pump. When I crank the motor though I get no fuel from the injection pump. It is a Bosch pump with a rack (slide). It seems to me that I've got the pin on the rack into the bracket inside the pump opening properly. I'm wondering if there is something not allowing the rack to slide open to allow fuel into the injectors???
Pic is of the pump in question.
Any ideas???
   / Mitsubishi KE130 No Fuel through Injection Pump #3
How much
   / Mitsubishi KE130 No Fuel through Injection Pump #4
Can u get to the control rack anywhere else on the engine.?
by removing a panel.?
Do u trust the pump evaluation.??
It needed to be looked at with experienced eyes..
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2011 Doonan 53' Trailer (A52377)
2011 Doonan 53'...
Dump Box Truck Body (A52377)
Dump Box Truck...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
