Mitsubishi KE130 No Fuel through Injection Pump
   / Mitsubishi KE130 No Fuel through Injection Pump #1
nasfell
Mitsubishi D2000FD
I'm hoping someone has had the same problem.....
I've had the injection pump evaluated and there is no issue with the pump itself. Also I have positive fuel flow from the tank/filter to the injection pump. When I crank the motor though I get no fuel from the injection pump. It is a Bosch pump with a rack (slide). It seems to me that I've got the pin on the rack into the bracket inside the pump opening properly. I'm wondering if there is something not allowing the rack to slide open to allow fuel into the injectors???
Pic is of the pump in question.
Any ideas???
   / Mitsubishi KE130 No Fuel through Injection Pump #3
How much
   / Mitsubishi KE130 No Fuel through Injection Pump #4
Can u get to the control rack anywhere else on the engine.?
by removing a panel.?
Do u trust the pump evaluation.??
It needed to be looked at with experienced eyes..
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
