MITSUBISHI D2500
   / MITSUBISHI D2500 #1
AUSTIN WESTERN
FORD 861, MITSUBISHI D2500, FORD 8N, FORD 9N,
I JUST BOUGHT THIS TRACTOR AND IT RUNS FINE BUT THE TRANSMISSION IS STUCK IN LOW RANGE BECAUSE THE HIGH/LOW LEVER SEEMS TO BE DISCONNECTED INSIDE. THERE IS NO RESISTANCE TO THE LEVER AT ALL. I HAVE A POOR QUALITY DIAGRAM SHOWING THE LEVER AND SOME RELATED PARTS. THERE SEEMS TO BE A "ROD" OF SORTS THAT IS CONNECTED TO THE SHIFT LEVER AND RUNS TO THE REAR OF THE TRANSMISSION. I GUESS IT SLIDES THE H/L GEAR SET BACK AND FORTH. THIS "ROD" MAY BE DISCONNECTED OR BROKEN (I HOPE NOT) ANYONE KNOW IF THERE IS A "ROD" LIKE I SUSPECT AND COULD IT BE LOOSE? I HAVEN'T REMOVED THE TOP COVER YET. I WORK 24/7 AND HAVEN'T HAD TIME.
   / MITSUBISHI D2500 #2
The high/low and high/mid/low selectors move a linkage inside the transfer case(s) that slides along a horizontal shaft to engage or disengage different gear sets along main and countershafts. You are going to hate that tractor by the time you get it out of low range. Take my advice. Split it and take the tranny and transfer case to a tranny specialist. Or just sell it and chalk this up to experience about the grey market.
   / MITSUBISHI D2500 #3
The same thing could happen to a Non-Grey.
Eugene
   / MITSUBISHI D2500 #4
What a load of crap. Hope you aren't a doctor or lawyer because your advice sucks.
BTW, he posted this question under the Mitsubishi forum also and got some quick replies that helped him to figure out what to do and as it turned out, it was an easy fix.
   / MITSUBISHI D2500 #5
Amen, Kernopelli. I have a grey and a non-grey that are nearly identical except for the size of the engine. Both are very good tractors. There is an exact match for my grey also.
   / MITSUBISHI D2500
Just got back into town guys and checked the messages/replies/comments. Yes, my tractor is fixed. It took about 5 minutes to fix (once I got the trans. cover off, that is) and I am back to cutting 16 acres of grass every week and keeping 2.4 miles of gravel driveway graded. I am satisfied with the tractor and plan to keep it. Why not? It runs fine, very stingy on diesel, has enough power and came with a front end loader AND 4 ft bush hog.
Sure, it isn't a fire breathing 300 horsepower 4 wheel drive behemoth that will grade a road or cut grass at 50 mph, but it IS a $3500 investment bought a little over 1 month ago that will pay for itself in oh, another 6 weeks or so. The best part is I DON"T HAVE A GIANT LOAN TO PAY OFF. HA!
   / MITSUBISHI D2500 #7
Has anyone been able to find a front loader attachment for one of these tractors or know what will fit
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2009 IC Corporation PB105 School Bus (A48081)
2009 IC...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
2013 Chrysler Town and Country Touring Van (A48082)
2013 Chrysler Town...
2017 Ford F-250 Ext. Cab Reading Service Truck (A48081)
2017 Ford F-250...
434669 (A48836)
434669 (A48836)
