Mitsubishi D1650fd Brakes??
   / Mitsubishi D1650fd Brakes?? #1
Albajus
Bath, NY
Mitsubishi
Howdy friends.
I just Bought a Mitsubishi D1650FD 4x4
Runs, drives, shifts great. Just need a little help with the brakes.
Interesting enough, "several owners back", someone changed the engine over to a 3 cylinder Kubota. Pretty Cool.
   / Mitsubishi D1650fd Brakes?? #2
I can probably help, what questions do you have? You can take the brake rod loose and remove the bolts that hold the cover on. Pull the cover off and you will see two brake shoes inside.
i see the rods that go back to either side of the rear... but, theres no cover. The rod connects to the lever, and bolted directly to the cast of the rear.
(sorry, weird sentance)
Is that nuts that i would have to split the rear to service the brakes??
I hope I'm looking at that wrong.
This is what I'm looking at.
Wow. Thanks for the info.
I'll check it out.
   / Mitsubishi D1650fd Brakes?? #8
By the way, welcome to TBN, lots of good info here. The Kubota conversion is interesting. A lot would like to see pics of that too. Your 1650 originally had a 4 cylinder I think. One of my neighbors has one. Theirs is a 2wd and has experienced broken front spindles but no problem with the engine.
Well thank you very much. I have gleaned great stuff here in the past. Much appreciated!
This 1650 is no show peice but it will get the job done I think. I'd be glad to post some pics of the engine conversion. It was well done. Thanks again.
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2019 KENWORTH T880 DAY CAB ROAD TRACTOR (A51406)
2019 KENWORTH T880...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
flooring (A53424)
flooring (A53424)
1266 (A50490)
1266 (A50490)
