Mitsubishi D1650 4WD hydraulic problems?
   / Mitsubishi D1650 4WD hydraulic problems? #1
JB Sullivan
Kannapolis NC
mitsubishi d1650 4wd
Hi Folks, I'm brand new to any forum, This forum look like my kind of forum..Well here-goes.... I just bought a used tractor from a "preacher", well when I tried the tractor out everything seemed to work fine. I couldn't wait to try out the little tractor at my home. then I started encountreing problems right off, weak hydraulics, leak down of the 3 pt lift when running, checked fluid low and also milky looking oil, my first thought, low hyd. fld., it was low, and I guess the milky apearence of the hyd oil is cavitation, cheched engine oil, too much oil, my guess is bad pump or pump seal. does anyone have a copy of the hydraulic system schematics,or service/repair manual? thanks. also I noticed that the hour meter/tach was disconnected....go figure, if anyone can helpme with understanding the hydraulicsystem on this type tractor it would greatly be appreciated...sincerely, Brent
   / Mitsubishi D1650 4WD hydraulic problems? #2
Welcome to TBN. :)
   / Mitsubishi D1650 4WD hydraulic problems? #3
Welcome to TBN!!! Wow...I hope you get all your problems resolved...You might find more help in the Hydraulics section.
   / Mitsubishi D1650 4WD hydraulic problems? #4
Hey there! Welcome to TractorByNet! :D I have moved your thread to the Hydraulics Forum. You will have better luck finding assistance there. :thumbsup:
   / Mitsubishi D1650 4WD hydraulic problems? #5
Milky fluid is an indication of water in the hyd system. Drain and replace with correct fluid, and do the filters at the same time.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 INTERNATIONAL LF687 (INOPERABLE) (A53843)
2016 INTERNATIONAL...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
KENWORTH T/A DAY CAB TRAD TRACTOR (A52706)
KENWORTH T/A DAY...
NEW Woods Reverse Rotation 5ft Tiller (A53473)
NEW Woods Reverse...
