Mitsubishi D1500
/ Mitsubishi D1500 #1
txbowler
Palestine, Texas
Mitsubishi D1500
Replaced battery, now it won't start. Can hear the clicking sound, but only occasionally. Otherwise, nothing. What should I look for??
/ Mitsubishi D1500 #2
Sounds like you've got a bad electrical connection somewhere, probably in the battery terminal end or where the ground ties into the frame. Once you've cleaned and re tightened them, try shorting across the solenoid with a screwdriver. If it cranks that way, then you've got some kind of problem between the switch and the solenoid.
/ Mitsubishi D1500
Have power, everything lights up when switch is turned on, just no turning over, not even a clicking sound. I guess replacing the switch would be the least expensive to try. Ground off battery is tight, all connections to solenoid are tight.
100" Bucket (A64119)
More info coming soon (A61569)
More info coming...
2012 LincolnMKX Hybird Sedan (A61574)
2012 LincolnMKX...
UNUSED AGT 12EX-ATA MINI EXCAVATOR (A64281)
UNUSED AGT...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
