mitsu D2650FD...gettin' started
/ mitsu D2650FD...gettin' started #11
Thanks for the correction Oliver28472... Len is a great knowledge base also....
after an exchange to get the water pump that stuck out far enough, we have a winner...so far no leaks
the tach cable and ignition switch came in also, so I should have the dash back together tomorrow
the air intake hose had a hole worn in it, so with a little help from HD, we have this...
nice to be able to put stuff back together again...still waiting on the new alt mount
have a good weekend!
/ mitsu D2650FD...gettin' started #13
Do I see a plug on the water pump just above the bottom hose? Is so, you could remove that and use that spot for a gauge.
yep...that plug used to be part of a bypass from below the thermostat back into the water pump...I'm not gonna run a thermostat, so it's just plugged.
just above that (and below the thermostat spot in the head) is the temp gauge probe. kind of a dark picture...apologies.
got a few little things done today like headlight bulbs (and something else) while I waited for the stove to warm up the garage...oh yeah, installed new tach cable.
took me a while to get the ignition switch figured...a cheap parts house one had been swapped in. in the end it was the battery in my DMM that needed replacing...then everything checked out fine. was able to get the wiring tidy-ed up under the dash. removed the regulator, and installed some jumpers to utilize existing wiring for field and sensor connections on the new alternator. still waiting on the alt mount. :dance1:
was going to add wire loom, but zip ties worked better, and made more sense
took me a while to get the throttle linkage figured again...it's been awhile since I took it apart
gotta make a run for a FEL bolt and a new v-belt...will probably wait until alt mount comes in
cheers!
so...she's runnin', and everything works (except the temp gauge stopped)...put the old alternator on as an idler, and the battery oughta last until the mount comes in. hydraulics primed themselves pretty quickly. man, those glowplugs sure cycle fast!
can anyone give me some insight on the VTEKS loaders on these little tractors? when the FEL is at full height, the bucket only tips forward to level...no way I could completely dump the bucket at full lift. is this normal? (not what I expected)
now, the original tilt cyl's have been swapped out for some farm store models, so maybe they just don't have enough throw? before I start chasing cylinders I thought I'd ask...
cheers!
/ mitsu D2650FD...gettin' started #18
VTEK.jpgYZoutlet has a sticky at the top of the hydraulics forum. I don't know anything about them but they have some great prices. They don't have an exact match to the V2 cylinder specs that Scotty Dive posted but they have a 14" stroke cross tube for $65. It could probably be cut down and rewelded/modified to the correct stroke and length specs if someone wanted to put some effort into making them a better match. I cut/rewelded all the cylinders on my FEL and it was actually a pretty easy chore. Welded Tube Cross Cylinders - YZOUTLET
Also added a pic of a VTEK at full height an tilt angle
awesome...thank you! that is what I was expecting, but currently ain't even close.
I'll check out that sticky, and do some figuring on what stroke is needed...after this blizzard settles down.
forgot to mention I have a V3.
well...the alternator mount came in finally.
you can see it's mod'd a bit from the original sketches
and it was a bit cold today, so I baked the paint on
it mounted up okay...took some finnegeling to find the sweet spot
and she wired up okay...made a pigtail setup with 90 degree connectors (for the idiot light and exciter connections) for clearance when loosening tension on the belt
found a v-belt that worked...42" by 1/2" wide...the alignment ain't perfect, but this ain't the space shuttle either...it'll run forever
and the CHG idiot light functions properly!
I ended up using existing wiring as much as possible (much cleaner, and less confusing later on...minmal ghost wires), which means I added some jumpers at the old regulator plug. now I have a commonly available alternator with an internal regulator.
cheers!
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Giyi 44" Excavator Rake w/ Shank (A60463)
Giyi 44" Excavator...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
