Mits steering wheel replacement
   / Mits steering wheel replacement #1
BTackett
Knoxville, Tn
Wanting to replace the warped/black dry rotted steering wheel on my MT372. Are all the Mitsu center steering wheel shafts universal? Is a puller necessary to remove the wheel?
thanks,
Bill
   / Mits steering wheel replacement #2
Good question...to which I have no answer for since my wheel is still all there and have not had to go down that path...yet:)
I hope someone has an answer. My little girl jumped on mine this morning and before I could get her some gloves her hands were BLACK!
   / Mits steering wheel replacement #4
Can't help with the replacement, but you could spray the wheel with clear gloss polyurethane, and it will keep the black stuff on the wheel, and off your hands!:D
I thought about that and wondered if it would work. I also have some heavy duty 2 inch black nylon tape to wrap it in also.
thanks,
Bill
   / Mits steering wheel replacement #6
What about one of them vinyl; steering wheel wraps folks used to put on their steering wheels, that would be a cheap intermediate fix till something more permanent came around.
   / Mits steering wheel replacement #8
The plastic is dry and the residue is what is coming off!
Feed the plastic a penetrating liquid that dries hard and you should be OK.
You would first steel wool away excess dry stuff prior to the 'feeding process'.
Think I used ARMORALL once to do that with success, but again it was perhaps laquer.
Even a good quality car wax would be better than nothing as it would 'feed' and dry hard.
I actually wax my wheel from time to time and have no cracks of residues.
Well , I got the old steering wheel off last night. It is in pitiful shape. It has a 36 spline 3/4 taper shaft.
Anyone know who makes a universal replacement wheel?
Bill
   / Mits steering wheel replacement #10
i can supply a 36 spline steering wheel.
2368 (A60432)
2368 (A60432)
S/A Yard Dog Truck (A59230)
S/A Yard Dog Truck...
UNUSED FUTURE FTH50-(50)SHEETS OFGALVALUME (A60432)
UNUSED FUTURE...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2010 Case 580N (A60462)
2010 Case 580N...
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
