Mits 2500D overheating
/ Mits 2500D overheating #1
Mephto
I have a 2500D that is overheating when I use the PTO. I have replaced the oilin the implement, oil in the 2500D, flushed the radiator, changed the hydrolic fluid and now have no idea what to do next.
Please help
/ Mits 2500D overheating #2
Not familiar with the 2500D, how much HP and what are you doing? What makes you think that the engine is overheating?
its a 30hp tractor. I am using a 5ft brush hog on it, which I have used for years with it. The tempature guage is sky rocketing after about 10 min of use. It will cool down if I turn the PTO off.
ces
/ Mits 2500D overheating #4
Good, you are within the 5 HP per foot rule.
Check the easiest things first:
Bad temp gauge giving a false reading, check temp with another thermometer in the radiator or with a IR temp gun.
Oil in the coolant or coolant in the crankcase oil.....blown head gasket.
Are the radiators fins clean of seed, chaff? Look deep into the radiator.
T-stat working? With the engine running and warmed up you should see coolant circulate with the radiator cap off as the T-stat opens and closes.
The lower radiator hose should have a spring built into it. The spring keeps the hose from collapsing and chocking off the coolant flow.
Bad/worn out pump.
/ Mits 2500D overheating #5
check the wire and connection going to the temperature sending unit/sensor.run it without thermostat and c if there is a difference.if it runs cooler a possible clogged radiator/coolant passage/def thermostat.
Thank you guys, I will be checking all this today and will update.
ces
/ Mits 2500D overheating #7
What rpm's are you running? Friend of mine complained about his tractor overheating and he was bush hogging some heavy stuff at about half speed.
/ Mits 2500D overheating #8
Good point, the PTO should be turning 540 RPM and that translates to 2,000 2,200 RPM for the engine.:thumbsup:
/ Mits 2500D overheating #9
I had trouble with the small screen in front of radiator filling up with fine particles you have to take it out clean it. I only use the first and second positions on PTO to bush hog. good luck rt
/ Mits 2500D overheating #10
I've got a 2600 d with the same problem. I wonder if the battery and the air cleaner box, being located in front of the radiator, would have anything to do with the over heating?
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2016 YAMAHA YDREX6 ELECTRIC GOLF CART (A64280)
2016 YAMAHA YDREX6...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
JCB 510-56 TELESCOPIC FORKLIFT (A64279)
JCB 510-56...
2017 TOYOTA CAMRY SEDAN (A59912)
2017 TOYOTA CAMRY...
2006 FREIGHTLINER COLUMBIA T/A 6X4 DAYCAB TRACTOR TRUCK (A59912)
2006 FREIGHTLINER...
