Mits 2500D overheating
/ Mits 2500D overheating #1
Mephto
I have a 2500D that is overheating when I use the PTO. I have replaced the oilin the implement, oil in the 2500D, flushed the radiator, changed the hydrolic fluid and now have no idea what to do next.
Please help
/ Mits 2500D overheating #2
Not familiar with the 2500D, how much HP and what are you doing? What makes you think that the engine is overheating?
its a 30hp tractor. I am using a 5ft brush hog on it, which I have used for years with it. The tempature guage is sky rocketing after about 10 min of use. It will cool down if I turn the PTO off.
ces
/ Mits 2500D overheating #4
Good, you are within the 5 HP per foot rule.
Check the easiest things first:
Bad temp gauge giving a false reading, check temp with another thermometer in the radiator or with a IR temp gun.
Oil in the coolant or coolant in the crankcase oil.....blown head gasket.
Are the radiators fins clean of seed, chaff? Look deep into the radiator.
T-stat working? With the engine running and warmed up you should see coolant circulate with the radiator cap off as the T-stat opens and closes.
The lower radiator hose should have a spring built into it. The spring keeps the hose from collapsing and chocking off the coolant flow.
Bad/worn out pump.
/ Mits 2500D overheating #5
check the wire and connection going to the temperature sending unit/sensor.run it without thermostat and c if there is a difference.if it runs cooler a possible clogged radiator/coolant passage/def thermostat.
Thank you guys, I will be checking all this today and will update.
ces
/ Mits 2500D overheating #7
What rpm's are you running? Friend of mine complained about his tractor overheating and he was bush hogging some heavy stuff at about half speed.
/ Mits 2500D overheating #8
Good point, the PTO should be turning 540 RPM and that translates to 2,000 2,200 RPM for the engine.:thumbsup:
/ Mits 2500D overheating #9
I had trouble with the small screen in front of radiator filling up with fine particles you have to take it out clean it. I only use the first and second positions on PTO to bush hog. good luck rt
/ Mits 2500D overheating #10
I've got a 2600 d with the same problem. I wonder if the battery and the air cleaner box, being located in front of the radiator, would have anything to do with the over heating?
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
43023 (A59228)
43023 (A59228)
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2011 Chevrolet Silverado 1500 Truck (A63116)
2011 Chevrolet...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
2022 Coyote Renegade Trailer (A63116)
2022 Coyote...
