Miter Saw Station
   / Miter Saw Station #1
RobS
Super Member
Goshen, IN
None!
A bit more progress in my workshop this weekend, I built a permanent home for my miter saw. Naturally, I took some pictures to share along the way.
First pic is my old workstation /forums/images/graemlins/smile.gif
   / Miter Saw Station
After many measurements, sketches, calculations and a trip to the Big Box, I built the framework for the saw. It's mostly 2X4 lumber, glued and screwed together /forums/images/graemlins/smile.gif
   / Miter Saw Station
Then a plywood platform for the saw /forums/images/graemlins/smile.gif
   / Miter Saw Station
I skipped a step in the photos which was to build the surround around the saw. It provides the vertical structure between the saw base, the work supports and the top shelf. This is where the measurements and calculations paid off. In addition to the surround, this picture shows the dry fit of the work supports on each side. My basement has a nice little bump out which allows the saw to sit flush with the walls on either side. Without that, the whole thing would have to sit further out from the wall /forums/images/graemlins/smile.gif
   / Miter Saw Station
A different view of the same thing /forums/images/graemlins/smile.gif
   / Miter Saw Station
And the final product. I filled in the upper area with a shelf for storing other tools and added a short skirt below the saw to hide the framing. It's nothing fancy but it sure does work well. Best thing for me is it's always ready for a project, no matter how big or small /forums/images/graemlins/smile.gif
   / Miter Saw Station
Final picture showing a bit more detail. If anyone is interested, I'd be happy to post more detail /forums/images/graemlins/smile.gif
   / Miter Saw Station #8
Looking good. /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
   / Miter Saw Station #9
Very nice, good use of that nook.... /forums/images/graemlins/cool.gif
   / Miter Saw Station #10
Very nice design. The long tables will hold you in good stead. You will thank yourself over and over again over the years as you use that station. Good investment of your time.
Cliff
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55218)
NEW 2025 Load...
